HAVING
Function
This statement is used to embed a subquery in the HAVING clause. The subquery result is used as a part of the HAVING clause.
Syntax
1 2 3 | SELECT [ALL | DISTINCT] attr_expr_list FROM table_reference GROUP BY groupby_expression HAVING aggregate_func(col_name) operator (sub_query); |
Keyword
- All is used to return repeated rows. By default, all repeated rows are returned. It is followed by asterisks (*) only. Otherwise, an error will occur.
- DISTINCT is used to remove the repeated line from the result.
- The groupby_expression can contain a single field or multiple fields, and also can call aggregate functions or string functions.
- The operator includes the equation and inequation operators, and IN and NOT IN operators.
Precautions
- The to-be-queried table must exist. If this statement is used to query a table that does not exist, an error is reported.
- The sequence of sub_query and the aggregate function cannot be changed.
Example
To group the student_info table according to the name field, count the records of each group, and return the number of records in which the name fields in the student_info table equal to the name fields in the course_info table if the two tables have the same number of records, run the following statement:
1 2 3 | SELECT name FROM student_info GROUP BY name HAVING count(name) = (SELECT count(*) FROM course_info); |
