Updated on 2024-07-04 GMT+08:00
INNER JOIN
Function
This statement is used to join and return the rows that meet the JOIN conditions from two tables as the result set.
Syntax
SELECT attr_expr_list FROM table_reference
  {JOIN | INNER JOIN} table_reference ON join_condition;
Keyword
JOIN/INNER JOIN: Only the records that meet the JOIN conditions in joined tables will be displayed.
Precautions
  • The to-be-joined table must exist. Otherwise, an error is reported.
  • INNER JOIN can join more than two tables at one query.
Example
To join the course IDs from the student_info and course_info tables and check the mapping between student names and courses, run the following statement:
SELECT student_info.name, course_info.courseName FROM student_info
  JOIN course_info ON (student_info.courseId = course_info.courseId);
