GROUPING SETS
Function
This statement is used to generate the cross-table row and achieve the cross-statistics of the GROUP BY field.
Syntax
        1 2 3  |
        SELECT attr_expr_list FROM table_reference GROUP BY col_name_list GROUPING SETS(col_name_list);  |
Keyword
GROUPING SETS is the expansion of GROUP BY. For example:
- SELECT a, b, sum(expression) FROM table GROUP BY a, b GROUPING SETS((a,b));
    It can be converted to the following query:
1 2
SELECT a, b, sum(expression) FROM table GROUP BY a, b;
 - SELECT a, b, sum(expression) FROM table GROUP BY a, b GROUPING SETS(a,b);
It can be converted to the following two queries:
1 2 3
SELECT a, NULL, sum(expression) FROM table GROUP BY a; UNION SELECT NULL, b, sum(expression) FROM table GROUP BY b;
 - SELECT a, b, sum(expression) FROM table GROUP BY a, b GROUPING SETS((a,b), a);
1 2 3
SELECT a, b, sum(expression) FROM table GROUP BY a, b; UNION SELECT a, NULL, sum(expression) FROM table GROUP BY a;
 - SELECT a, b, sum(expression) FROM table GROUP BY a, b GROUPING SETS((a,b), a, b, ());
    It can be converted to the following four queries:
1 2 3 4 5 6 7
SELECT a, b, sum(expression) FROM table GROUP BY a, b; UNION SELECT a, NULL, sum(expression) FROM table GROUP BY a, NULL; UNION SELECT NULL, b, sum(expression) FROM table GROUP BY NULL, b; UNION SELECT NULL, NULL, sum(expression) FROM table;
Precautions
- The to-be-grouped table must exist. Otherwise, an error is reported.
 - Different from ROLLUP, there is only one syntax for GROUPING SETS.
Example
To generate the cross-table row according to the group_id and job fields and return the total salary on each aggregation condition, run the following statement:
        1 2 3  |
        SELECT group_id, job, SUM(salary) FROM group_test GROUP BY group_id, job GROUPING SETS (group_id, job);  |
