Restoring a Delta Table to an Earlier State
Syntax
Restore a Delta table to the state at a specific point in time:
RESTORE [TABLE] [database_name.]table_name|DELTA.`obs_path`
[TO] TIMESTAMP AS OF timestamp_expression
Restore a Delta table to the state at a specific historical version:
[TO] VERSION AS OF version_code
Parameter Description
Parameter |
Description |
database_name |
Name of the database, consisting of letters, numbers, and underscores (_) |
table_name |
Name of the table in the database, consisting of letters, numbers, and underscores (_) |
obs_path |
OBS path, indicating the storage location of the Delta table |
timestamp_expression |
Timestamp, which cannot be later than the current time, formatted as yyyy-MM-ddTHH:mm:ss.SSS |
version_code |
Version number in the query result in Viewing History Operation Records of a Delta Table |
Example
RESTORE delta_table0 TO TIMESTAMP AS OF '2020-10-18T22:15:12.013Z'; RESTORE delta.`obs://bucket_name/db0/delta_table0` VERSION AS OF 2;
