What Are the Differences Between Using a Public NAT Gateway and Using an EIP for an ECS?
A public NAT gateway provides SNAT and DNAT, so multiple ECSs can share an EIP.
An ECS can also have an EIP bound to it. The EIP does not have to be shared.
If both SNAT and EIP are configured for an ECS, data will be forwarded through the EIP.
If both DNAT and EIP are configured for an ECS, the ECS will have two EIPs, one that is directly bound to the ECS and one that is associated with the DNAT rule. Incoming data will be forwarded by one of the two EIPs, which is determined by the client user. Outgoing data will be forwarded by the EIP directly bound to the ECS in priority. If the two EIPs are different, data forwarding will fail.
Configuring both a public NAT gateway and an EIP for an ECS is not recommended.
Public NAT Gateways FAQs
- What Is the Relationship Between a VPC, Public NAT Gateway, EIP Bandwidth, and ECS?
- How Does a Public NAT Gateway Offer High Availability?
- Which Ports Cannot Be Accessed?
- What Are the Differences Between Using a Public NAT Gateway and Using an EIP for an ECS?
- What Should I Do If I Fail to Access the Internet Through a Public NAT Gateway?
- Can I Change the VPC for a Public NAT Gateway?
- Does Public NAT Gateway Support IPv6 Addresses?
- What Security Policies Can I Configure to Implement Access Control If I Use a Public NAT Gateway?
- What Can I Do If Connection Between My Servers and the Internet Fails After I Add SNAT and DNAT Rules?
Chatbotmore
