Help Center/ Cloud Container Engine/ User Guide (Kuala Lumpur Region)/ FAQs/ Cluster/ Cluster Upgrade/ What Should I Do If the LoadBalancer Ingress Configuration Is Inconsistent with the Load Balancer Configuration During a CCE Cluster Upgrade?
Updated on 2025-12-08 GMT+08:00
ELB Resources
In a CCE cluster, LoadBalancer ingresses are used to route external traffic to Services within the cluster. The parameters defined in an ingress are applied to configure a load balancer for effective traffic management and distribution. Table 1 lists the mapping between load balancer configuration and ingress parameters.
Table 1 Mapping between load balancer configuration and LoadBalancer ingresses
Mapping in a LoadBalancer Ingress
Load balancer (elb)
Distribute incoming traffic across backend servers in one or more AZs.
kubernetes.io/elb.id in ingress annotations
Listener (listener)
Use the protocol and port you specify to check for requests from clients and route the requests to associated backend servers based on the routing rules you define.
kubernetes.io/elb.port in ingress annotations, which defaults to 80/443 if not defined
Forwarding policy (l7policy)
Forwarding policy
Load balancer forwarding rules: domain names or paths
Domain name and path in the forwarding rule: spec.rules[].host and spec.rules[].http.paths[].path in the ingress parameters, respectively
Load balancer forwarding actions: forward to a backend server group
Backend server group: the backend service of the associated Service specified by spec.rules[].http.paths[].backend.service in the ingress
Advanced forwarding policy
Load balancer forwarding rules: domain names, paths, HTTP request methods, HTTP headers, query strings, or CIDR blocks
The annotations related to advanced forwarding policies such as kubernetes.io/elb.actions and kubernetes.io/elb.conditions in the ingress annotations
Load balancer forwarding actions: forward to a backend server group, redirect to another listener, redirect to another URL, return a specific response body, rewrite, write header, remove header, and limit request
Backend server group (pool)
A backend server group is a logical collection of one or more backend servers to receive massive requests concurrently. A backend server can be an ECS, supplementary network interface, or IP address.
spec.rules[].http.paths[].backend in the ingress parameters
Backend server (member)
Backend servers receive and process requests from the associated load balancer. For example, you can add an ECS as a backend server of a load balancer. The listener checks connection requests from clients using the configured protocol and port and forwards the requests to the backend servers in the backend server groups based on the load balancing algorithm you set.
Endpoint of the Service associated with the ingress
Troubleshooting Inconsistency Between Ingress and Load Balancer Configuration
During a pre-upgrade cluster check, many discrepancies between ingress and load balancer configuration may be identified. For each inconsistent item, CCE provides the expected configuration details. An example is as follows:
inconsistent: ingress(default/nginx) need create listener(HTTP/8000) of elb(4a090bf3-9d11-45dc-8d04-f9cf010ba2ec), the wanted configuration is {"name":"k8s_HTTP_8000","protocol_port":8000,"protocol":"HTTP","loadbalancer_id":"4a090bf3-9d11-45dc-8d04-f9cf010ba2ec","sni_container_refs":null,"http2_enable":false}
inconsistent: ingress(default/nginx) need create pool(k8s_default_nginx-80_HTTP-8000), the wanted configuration is {"name":"k8s_default_nginx-80_HTTP-8000","protocol":"HTTP","loadbalancer_id":"4a090bf3-9d11-45dc-8d04-f9cf010ba2ec","lb_algorithm":"ROUND_ROBIN","slow_start":{"enable":false,"duration":30}}
inconsistent: need create member(address: 172.16.0.54) of pool(k8s_default_nginx-80_HTTP-8000), the wanted configuration is {"name":"2c2405d1abc17da48c70e9edc9a340fc","subnet_cidr_id":"77b9ad29-e30f-451b-92e7-949b83220b0f","address":"172.16.0.54","protocol_port":30838,"weight":6}
inconsistent: ingress(default/nginx) need create l7policy(k8s_default_nginx_6666cd76) of listener(k8s_HTTP_8000/HTTP/8000), the wanted configuration is {"name":"k8s_default_nginx_6666cd76","listener_id":"k8s_HTTP_8000/HTTP/8000","action":"REDIRECT_TO_POOL","redirect_pool_id":"k8s_default_nginx-80_HTTP-8000"}
 inconsistent: ingress(default/nginx) need create rule of l7policy(k8s_default_nginx_6666cd76), the wanted configuration is {"type":"PATH","compare_type":"STARTS_WITH","value":"/"}
You can perform the following operations in sequence.
Inconsistent Listeners: A Listener Needs to Be Created
inconsistent: ingress(xxx) need create listener ...
When a listener's name or description is modified or a listener is deleted from the ELB console, this problem arises. In this case, you can use the port to check whether the listener is available on the ELB console and if its name and description match the expected configuration.
The listener description should resemble the following, where cluster_id represents the ID of the cluster:
{"attention":"Auto-generated by CCE service, do not modify!","cluster_id":"5d4d44bd-0891-11f0-84d3-0255ac10003e"}
For example:
This indicates that an Nginx ingress in the default namespace needs a listener with port 8000 and protocol HTTP under the load balancer 4a090bf3-9d11-45dc-8d04-f9cf010ba2ec. The listener should be named k8s_HTTP_8000, with sni_container_refs set to null and http2_enable set to false. The description also needs to be specified.
Inconsistent Listeners: A Listener Needs to Be Updated
inconsistent: ingress(xxx) need update listener ...
When the listener configuration is modified on the ELB console but is not synchronized with CCE, this problem arises. In this case, you can check the ELB console for the actual configuration and compare it with the expected configuration. If there is any inconsistency, you can update the listener manually or modify the ingress as needed.
For example:
inconsistent: ingress(default/cce-elb-ingress) need update listener(5ca8a931-9d7a-465e-b503-08f88d528cd8), the wanted configuration is {"id":"5ca8a931-9d7a-465e-b503-08f88d528cd8","sni_container_refs":null}
The expected configuration of the listener is displayed after the wanted configuration is. In this example, the expected configuration is sni_container_refs: null. In this case, you can check whether the SNI function is enabled for the ELB listener but is missing in the ingress. If so, add the SNI configuration to the ingress. For details, see Configuring SNI for a LoadBalancer Ingress.
Inconsistent Forwarding Policies: A Forwarding Policy Needs to Be Created
inconsistent: ingress(xxx) need create l7policy(xxx) ...
When the description of a forwarding policy created by CCE is modified on the ELB console or a forwarding policy created by CCE is deleted on the ELB console, this problem arises. In this case, you can verify the policy's existence on the ELB console by its name and check whether the description matches the expected configuration.
The following shows an example for the description of a forwarding policy. The value of cluster_id is the ID of the current cluster, and the value of ingress_id is the UID of the current ingress.
{"attention":"Auto-generated by CCE service, do not modify!","cluster_id":"5d4d44bd-0891-11f0-84d3-0255ac10003e","ingress_id":"8a79a17b-f9ab-4431-95f6-0e1125093aac"}
The ELB console does not provide a direct view of forwarding policy descriptions. To access this information, you must retrieve it from the data returned through the browser interface.
For example:
inconsistent: ingress(default/nginx) need create l7policy(k8s_default_nginx_6666cd76) of listener(0bdabd92-a85b-4f9b-96df-0fde706ea028), the wanted configuration is {"name":"k8s_default_nginx_6666cd76","listener_id":"0bdabd92-a85b-4f9b-96df-0fde706ea028","action":"REDIRECT_TO_POOL","redirect_pool_id":"k8s_default_nginx-80_HTTP-8000"}
This indicates that the Nginx ingress in the default namespace needs a forwarding policy named k8s_default_nginx_6666cd76 under the listener 0bdabd92-a85b-4f9b-96df-0fde706ea028, and traffic needs to be forwarded to the backend server group named k8s_default_nginx-80_HTTP-8000. The description also needs to be specified. You can call the API for creating a forwarding policy.
You can view the created forwarding policy in the returned information via the browser interface.
Inconsistent Forwarding Policies: A Forwarding Policy Needs to Be Updated
inconsistent: ingress(xxx) need update l7policy(xxx) of listener(xxx) ...
When the backend server group (redirect_pool_id) of the forwarding policy created by CCE is modified on the ELB console, this problem arises. For example:
inconsistent: ingress(default/nginx) need update l7policy(c4beb313-0a32-4add-9d0e-68b8f0f90e01) of listener(0bdabd92-a85b-4f9b-96df-0fde706ea028), the wanted configuration is {"id":"c4beb313-0a32-4add-9d0e-68b8f0f90e01","redirect_pool_id":"k8s_default_nginx-80_HTTP-8000","redirect_pools_config":[]}
This indicates that for the Nginx ingress in the default namespace, the redirect_pool_id in the forwarding policy c4beb313-0a32-4add-9d0e-68b8f0f90e01 must be updated to the backend server group ID of k8s_default_nginx-80_HTTP-8000 under the listener 0bdabd92-a85b-4f9b-96df-0fde706ea028. Additionally, the redirect_pools_config should be deleted.
Inconsistent Forwarding Policies: A Forwarding Policy Needs to Be Deleted
inconsistent: ingress(xxx) need delete l7policy(id: xxx) ...
When a forwarding policy is created on the ELB console for the listener that is created by CCE, this problem arises. In this case, you can locate the forwarding policy based on its ID and then delete it.
For example:
inconsistent: need delete l7policy(id: f4eda0af-869a-47fb-a699-2f27f286b641)
You can call the API for viewing details of a forwarding policy to see which ELB listener the forwarding policy applies and then delete the forwarding policy. If you want to keep the forwarding policy, add the corresponding configuration to the ingress.
Inconsistent Forwarding Rules: A Forwarding Rule Needs to Be Created or Deleted
inconsistent: ingress(xxx) need create rule of l7policy(xxx) ...
When the forwarding rule of a forwarding policy created by CCE is modified on the ELB console, this problem arises. Typically, changes to the rule type, matching mode, or path result in discrepancies. CCE handles forwarding rule updates by deleting and recreating them, which often leads to simultaneous creation and deletion issues.
For example:
inconsistent: need delete rule(6cf87a3e-373e-4378-bf7a-16a709feee63) of l7policy(c4beb313-0a32-4add-9d0e-68b8f0f90e01)
This indicates that for the Nginx ingress in the default namespace, a forwarding rule needs to be created for the k8s_default_nginx_6666cd76 policy. The rule's type should be PATH, the matching mode should be STARTS_WITH (prefix matching), and the value should be /. Additionally, you need to delete the forwarding rule 6cf87a3e-373e-4378-bf7a-16a709feee63 from the forwarding policy c4beb313-0a32-4add-9d0e-68b8f0f90e01.
Inconsistent Backend Server Groups: A Backend Server Group Needs to Be Created
inconsistent: need create pool(xxx)...
When the backend server group (redirect_pool_id) of the forwarding policy created by CCE is modified on the ELB console, this problem arises. Typically, the system displays the message "need update l7policy ...". In this case, you can check if the backend server group exists by its name or listener. If the group exists, update the backend server group of the forwarding policy.
For example:
If the group does not exist, create one based on the printed configuration items.
Inconsistent Backend Servers: A Backend Server Needs to Be Created
inconsistent: need create member(address: xxx) of pool(xxx) ...
When a backend server in a backend server group created by CCE is modified on the ELB console, this problem arises.
For example:
inconsistent: need create member(address: 172.16.0.54) of pool(dab7b0c1-623e-4499-8c70-7477f36fc2ef), the wanted configuration is {"name":"2c2405d1abc17da48c70e9edc9a340fc","subnet_cidr_id":"77b9ad29-e30f-451b-92e7-949b83220b0f","address":"172.16.0.54","protocol_port":30838,"weight":6}
This indicates that a backend server 2c2405d1abc17da48c70e9edc9a340fc with the IP address 172.16.0.54, port 30838, weight 6, and subnet 77b9ad29-e30f-451b-92e7-949b83220b0f needs to be added to the backend server group dab7b0c1-623e-4499-8c70-7477f36fc2ef. You cannot enter a backend server name on the ELB console, but you can call the API for adding a backend server.
Inconsistent Backend Servers: A Backend Server Needs to Be Updated
inconsistent: need update member(address: xxx) of pool(xxx) ...
When the weight of a backend server in the backend server group created by CCE is changed on the ELB console, this problem arises.
For example:
inconsistent: need update member(9a65b96c-891a-439e-a692-508c3e095095) of pool(dab7b0c1-623e-4499-8c70-7477f36fc2ef), the wanted configuration is {"id":"9a65b96c-891a-439e-a692-508c3e095095","name":"2c2405d1abc17da48c70e9edc9a340fc","weight":6}
This indicates that you need to change the weight of the backend server 9a65b96c-891a-439e-a692-508c3e095095 in the backend server group dab7b0c1-623e-4499-8c70-7477f36fc2ef to 6.
Inconsistent Backend Servers: A Backend Server Needs to Be Deleted
inconsistent: need delete member(address: xxx) of pool(xxx) ...
For example:
inconsistent: need delete members([d0891296-daf9-496b-9cac-ad1a1101b303]) of pool(dab7b0c1-623e-4499-8c70-7477f36fc2ef)
This indicates that you need to delete the backend server d0891296-daf9-496b-9cac-ad1a1101b303 from the backend server group dab7b0c1-623e-4499-8c70-7477f36fc2ef.
Inconsistent Health Check Settings: Health Checks Need to Be Removed
inconsistent: need delete healthMonitor(xxx) of pool(xxx) ...
When the health checks of a backend server group created by CCE are enabled on the ELB console but are not configured in the ingress, this problem arises.
For example:
inconsistent: need delete healthMonitor(ef7ad2c3-bdda-4727-8a1c-de37eeb48b55) of pool(402dbff8-58b8-4a49-bb99-0dc5cf87c35b)
This indicates that the health check associated with the backend server group 402dbff8-58b8-4a49-bb99-0dc5cf87c35b needs to be removed. You can call the API for deleting a health check. You can also enable the health check in the ingress.
Inconsistent Health Check Settings: Health Checks Need to Be Updated
inconsistent: need update healthMonitor(xxx) of pool(xxx) ...
When the health checks of a backend server group created by CCE are modified on the ELB console, this problem arises.
For example:
inconsistent: need update healthMonitor(9d438b19-4342-42af-a876-77d49bbc9447) of pool(402dbff8-58b8-4a49-bb99-0dc5cf87c35b), the wanted configuration is {"delay":5,"max_retries":3,"timeout":10,"type":"HTTP","url_path":"/","monitor_port":null,"admin_state_up":true}
This indicates that the health check 9d438b19-4342-42af-a876-77d49bbc9447 must be updated to match the desired settings.
Common Issues
  • Why is "need create" displayed when the listener, Layer 7 policy (l7policy), or pool exists?
    Solution
    Resources managed by CCE must have descriptions. You need to check whether the descriptions exist.
