What Should I Do If Residual Process Resources Exist Due to an Earlier npd Add-on Version?
When the node load is heavy, residual CCE Node Problem Detector process resources may exist.
Symptom
After successful login to the ECS node where the CCE cluster runs, it is found that there are a large number of CCE Node Problem Detector processes exist.
Solution
Upgrade the CCE Node Problem Detector add-on to the latest version.
- Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons, locate the CCE Node Problem Detector add-on, and click Upgrade.
If the CCE Node Problem Detector add-on version is 1.13.6 or later, you do not need to upgrade it.
- In the window that slides out from the right, configure the parameters and click OK.
