Updated on 2025-07-07 GMT+08:00
Configuring Redirection Rules for an Nginx Ingress
Configuring a Permanent Redirection Rule
To permanently redirect an access request to a target website (status code 301), use the nginx.ingress.kubernetes.io/permanent-redirect annotation. For example, to permanently redirect all access requests to www.example.com, run the following command:
nginx.ingress.kubernetes.io/permanent-redirect: https://www.example.com
The configuration in an Nginx Ingress is as follows:
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    For clusters of v1.23 or later:
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    name: <your_service_name>  # Replace it with the name of your target Service.
                    port:
                      number: <your_service_port>  # Replace it with the port number of your target Service.
                property:
      ingressClassName: nginx
    For clusters of v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      namespace: default
      annotations:
        kubernetes.io/ingress.class: nginx
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  serviceName: <your_service_name>  # Replace it with the name of your target Service.
                  servicePort: <your_service_port>  # Replace it with the port number of your target Service.
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME          CLASS   HOSTS     ADDRESS          PORTS   AGE
    ingress-test  nginx   *         121.**.**.**     80      10s
  5. Access the ingress. ${ELB_IP} specifies the IP address of the load balancer associated with the Nginx ingress.
    curl -I ${ELB_IP}
    The access path will be redirected to www.example.com.
    HTTP/1.1 301 Moved Permanently
    Date: Sat, 20 Jul 2024 07:55:49 GMT
    Content-Type: text/html
    Content-Length: 162
    Connection: keep-alive
Configuring the Returned Status Code for the Permanent Redirection Rule
When configuring a permanent redirection rule, you can use the nginx.ingress.kubernetes.io/permanent-redirect-code annotation to modify its returned status code. For example, to set the status code for the permanent redirection to 308, run the following command:
nginx.ingress.kubernetes.io/permanent-redirect-code: '308'
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                property:
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
    kubectl get ingress
    curl -I ${ELB_IP}
    The access path will be redirected to www.example.com, and the status code is 308.
    HTTP/1.1 308 Moved Permanently
    Content-Length: 162
Configuring a Temporary Redirection Rule
To temporarily redirect an access request to a target website (status code 302), use the nginx.ingress.kubernetes.io/temporal-redirect annotation. For example, to temporarily redirect all access requests to www.example.com, run the following command:
nginx.ingress.kubernetes.io/temporal-redirect: https://www.example.com
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                property:
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
    kubectl get ingress
    curl -I ${ELB_IP}
    The access path will be redirected to www.example.com, and the status code is 302.
    HTTP/1.1 302 Moved Temporarily
    Date: Sat, 20 Jul 2024 08:01:02 GMT
    Content-Length: 138
Redirecting HTTP to HTTPS
By default, if an ingress uses TLS, requests will be redirected (status code 308) to HTTPS when HTTP is used for access. You can configure the redirection by using the nginx.ingress.kubernetes.io/ssl-redirect annotation.
  • If the value of this annotation is set to true, an HTTP access is redirected to HTTPS (status code 308) when the TLS certificate is used.
  • If the value of this annotation is set to false, an HTTP access cannot be redirected to HTTPS when the TLS certificate is used.
If you need to forcibly redirect an HTTP access to HTTPS without a TLS, you can configure the redirection by setting the value of nginx.ingress.kubernetes.io/force-ssl-redirect to true.
    kind: Ingress
      namespace: default
      annotations:
        nginx.ingress.kubernetes.io/force-ssl-redirect: 'true'
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
                  service:
                    port:
                property:
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: /
                backend:
    kubectl get ingress
    curl -I ${ELB_IP}
    The access path will be redirected to HTTPS, and the status code is 308.
    HTTP/1.1 308 Permanent Redirect
    Date: Sat, 20 Jul 2024 08:03:36 GMT
    Content-Length: 164
