Using GPU Virtualization
This section describes how to use the GPU virtualization capability to isolate the computing power from the GPU memory and efficiently use GPU device resources.
- You have prepared GPU virtualization resources.
- To create a cluster using commands, ensure kubectl is used. For details, see Accessing a Cluster Using kubectl.
Notes and Constraints
- A single GPU can be virtualized into a maximum of 20 virtual GPU devices.
- Virtualized GPUs cannot be used in init containers.
- GPU virtualization supports GPU memory isolation and isolation between GPU memory and computing power. A single GPU can schedule only workloads in the same isolation mode.
- Autoscaler cannot be used to automatically scale in or out virtualized GPU nodes in clusters of v1.27 or earlier.
- When isolation is required, virtualized GPUs do not support requesting GPU memory using the CUDA API cudaMallocManaged(), which is also known as Unified Virtual Memory (UVM). For more information, see NVIDIA official documents. Use other methods to request for GPU memory, for example, by calling cudaMalloc().
- When a containerized application is initializing, the real-time compute monitored by the nvidia-smi may exceed the upper limit of the available compute of the container.
- When GPU virtualization is enabled on a node with multiple GPUs, insufficient GPU resources will not result in the preempting of GPU resources from other pods.
Creating a GPU Virtualization Application
Using the CCE Console
- Log in to the CCE console.
- Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and click the Create Workload in the upper right corner.
- Configure basic information of the workload.
In Basic Info under Container Settings, configure the GPU quota.
- GPU memory: The unit is MiB. The value must be a positive integer that is a multiple of 128. If the value exceeds the memory of a single GPU, scheduling cannot be performed.
- Computing Power: The unit is %. The value must be a multiple of 5 and cannot exceed 100.
- If the GPU memory is set to the capacity upper limit of a single GPU or the computing power is set to 100%, the entire GPU will be used.
- When GPU virtualization is used, the workload scheduler defaults to Volcano and cannot be changed.
This section describes how to use GPU virtualization. For details about other parameters, see Workloads.
After the configuration, click Create Workload.
- After a workload is created, you can try to verify the isolation capability of GPU virtualization.
- Log in to the pod and check the total GPU memory allocated to the pod.
kubectl exec -it gpu-app -- nvidia-smi
Expected output:
Wed Apr 12 07:54:59 2023 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 Tesla V100-SXM2... Off | 00000000:21:01.0 Off | 0 | | N/A 27C P0 37W / 300W | 0MiB / 5120MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| +-----------------------------------------------------------------------------+
The pod does not use GPU resources. Therefore, although the total GPU memory allocated to the container is 5120 MiB, the actual usage is 0 MiB. After GPU programs are deployed in the pod, the actual GPU usage will no longer be 0 MiB.
- Run the following command on the node to check the isolation status of the GPU memory:
nvidia-smi
Expected output:
Wed Apr 12 09:31:10 2023 +-----------------------------------------------------------------------------+ | NVIDIA-SMI 470.57.02 Driver Version: 470.57.02 CUDA Version: 11.4 | |-------------------------------+----------------------+----------------------+ | GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC | | Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. | | | | MIG M. | |===============================+======================+======================| | 0 Tesla V100-SXM2... Off | 00000000:21:01.0 Off | 0 | | N/A 27C P0 37W / 300W | 0MiB / 16160MiB | 0% Default | | | | N/A | +-------------------------------+----------------------+----------------------+ +-----------------------------------------------------------------------------+ | Processes: | | GPU GI CI PID Type Process name GPU Memory | | ID ID Usage | |=============================================================================| | No running processes found | +-----------------------------------------------------------------------------+
The expected output indicates that the total GPU memory on the GPU node is 16160 MiB. Since the sample pod does not run any GPU program, the used GPU memory is 0 MiB.
Using kubectl
- Use kubectl to access the cluster.
- Create an application that uses GPU virtualization.
The GPU memory isolation and isolation between GPU memory and computing power are supported. The computing power cannot be isolated only. volcano.sh and gpu-core.percentage cannot be set separately.
Create a gpu-app.yaml file with the following content.
- Isolate GPU memory only:
apiVersion: apps/v1 kind: Deployment metadata: name: gpu-app labels: app: gpu-app spec: replicas: 1 selector: matchLabels: app: gpu-app template: metadata: labels: app: gpu-app spec: containers: - name: container-1 image: <your_image_address> # Replace it with your image address. resources: limits: volcano.sh/gpu-mem.128Mi: 40 # GPU memory allocated to the pod. The value is a multiple of 128 MiB (40 x 128 = 5120 MiB). imagePullSecrets: - name: default-secret schedulerName: volcano
- Isolate the GPU memory from computing power:
apiVersion: apps/v1 kind: Deployment metadata: name: gpu-app labels: app: gpu-app spec: replicas: 1 selector: matchLabels: app: gpu-app template: metadata: labels: app: gpu-app spec: containers: - name: container-1 image: <your_image_address> # Replace it with your image address. resources: limits: volcano.sh/gpu-mem.128Mi: 40 # GPU memory allocated to the pod. The value is a multiple of 128 MiB (40 x 128 = 5120 MiB). volcano.sh/gpu-core.percentage: 25 # Computing power allocated to the pod imagePullSecrets: - name: default-secret schedulerName: volcano
Table 1 Key parameters Parameter
Mandatory
No
The value is a positive integer that is a multiple of 128 in the unit of MiB. If the value exceeds the memory of a single GPU, scheduling cannot be performed.
No
The unit of the computing power is %. The value must be a multiple of 5 and cannot exceed 100.
- Run the following command to create an application:
kubectl apply -f gpu-app.yaml
- Verify the isolation capability of GPU virtualization.
Expected output:
nvidia-smi
Expected output:
