Updated on 2024-01-24 GMT+08:00
Pod Check
Check Item
  • Check whether there are unexpected pods in the cluster.
  • Check whether there are any pods that ran properly originally in the cluster restart unexpectedly.
Log in to the CCE console and access the cluster console. Choose Workloads in the navigation pane. On the displayed page, switch to the Pods tab page. Select all namespaces, click Status, and check whether there are any abnormal pods.
View the Restarts column to check whether there are pods that are restarted abnormally.
Solution
If there are abnormal pods in your cluster after the cluster upgrade, contact technical support.
