Updated on 2025-07-07 GMT+08:00
Add-on Configuration Consistency
Check Items
Manual modifications to add-on configuration parameters (typically ConfigMaps), instead of modifications through the CCE console or APIs, may be overwritten after an upgrade, potentially affecting service operation.
Solution
  • Non-forced upgrades
    • When upgrading your cluster, if the add-on version is compatible with both the source and target cluster versions, you need to determine whether to upgrade the add-on version.
    • If the add-on configurations are inconsistent but a forced upgrade is not required, you can skip this check item and leave the add-on upgrade option unselected during the cluster upgrade.
  • Forced upgrades
    • If the add-on version is no longer compatible with the upgraded cluster version, you must upgrade the add-on version.
    • If the add-on configurations are inconsistent and a forced upgrade is required, you cannot skip this check item. In this case, reconfigure the add-on parameters through the CCE console or APIs to ensure configuration consistency before proceeding with the upgrade.
