Updated on 2024-01-24 GMT+08:00
Dynamic Resource Oversubscription
Many services see surges in traffic. To ensure performance and stability, resources are often requested at the maximum needed. However, the surges may ebb very shortly and resources, if not released, are wasted in non-peak hours. Especially for online jobs that request a large quantity of resources to ensure SLA, resource utilization can be as low as it gets.
Resource oversubscription is the process of making use of idle requested resources. Oversubscribed resources are suitable for deploying offline jobs, which focus on throughput but have low SLA requirements and can tolerate certain failures.
Hybrid deployment of online and offline jobs in a cluster can better utilize cluster resources.
Figure 1 Resource oversubscription
Features
After dynamic resource oversubscription and elastic scaling are enabled in a node pool, oversubscribed resources change rapidly because the resource usage of high-priority applications changes in real time. To prevent frequent node scale-ins and scale-outs, do not consider oversubscribed resources when evaluating node scale-ins.
Hybrid deployment is supported, and CPU and memory resources can be oversubscribed. The key features are as follows:
  • Offline jobs preferentially run on oversubscribed nodes.
    If both oversubscribed and non-oversubscribed nodes exist, the former will score higher than the latter and offline jobs are preferentially scheduled to oversubscribed nodes.
  • Online jobs can use only non-oversubscribed resources if scheduled to an oversubscribed node.
    Offline jobs can use both oversubscribed and non-oversubscribed resources of an oversubscribed node.
  • In the same scheduling period, online jobs take precedence over offline jobs.
    If both online and offline jobs exist, online jobs are scheduled first. When the node resource usage exceeds the upper limit and the node requests exceed 100%, offline jobs will be evicted.
  • CPU/memory isolation is provided by kernels.
    CPU isolation: Online jobs can quickly preempt CPU resources of offline jobs and suppress the CPU usage of the offline jobs.
    Memory isolation: When system memory resources are used up and OOM Kill is triggered, the kernel evicts offline jobs first.
  • kubelet offline jobs admission rules:
    After the the pod is scheduled to a node, kubelet starts the pod only when the node resources can meet the pod request (predicateAdmitHandler.Admit). kubelet starts the pod when both of the following conditions are met:
    • The total request of pods to be started and online running jobs < allocatable nodes
    • The total request of pods to be started and online/offline running job < allocatable nodes+oversubscribed nodes
  • Resource oversubscription and hybrid deployment:
    If only hybrid deployment is used, configure the label volcano.sh/colocation=true for the node and delete the node label volcano.sh/oversubscription or set its value to false.
    If the label volcano.sh/colocation=true is configured for a node, hybrid deployment is enabled. If the label volcano.sh/oversubscription=true is configured, resource oversubscription is enabled. The following table lists the available feature combinations after hybrid deployment or resource oversubscription is enabled.
    Hybrid Deployment Enabled (volcano.sh/colocation=true)
    Resource oversubscription Enabled (volcano.sh/oversubscription=true)
    Use Oversubscribed Resources
    Conditions for Evicting Offline Pods
    No
    No
    No
    None
    Yes
    No
    No
    The node resource usage exceeds the high threshold.
    No
    Yes
    Yes
    The node resource usage exceeds the high threshold, and the node request exceeds 100%.
    Yes
    Yes
    Yes
kubelet Oversubscription
Specifications
  • Cluster Version
    • v1.19: v1.19.16-r4 or later
    • v1.21: v1.21.7-r0 or later
    • v1.23: v1.23.5-r0 or later
    • v1.25 or later
  • Cluster Type: CCE or CCE Turbo
  • Node OS: EulerOS 2.9 (kernel-4.18.0-147.5.1.6.h729.6.eulerosv2r9.x86_64)
  • Node Type: ECS
  • The volcano add-on version: 1.7.0 or later
  • Before enabling oversubscription, ensure that the overcommit add-on is not enabled on volcano.
  • Modifying the label of an oversubscribed node does not affect the running pods.
  • Running pods cannot be converted between online and offline services. To convert services, you need to rebuild pods.
  • If the label volcano.sh/oversubscription=true is configured for a node in the cluster, the oversubscription configuration must be added to the volcano add-on. Otherwise, the scheduling of oversold nodes will be abnormal. Ensure that you have correctly configure labels because the scheduler does not check the add-on and node configurations. For details about the labels, see Table 1.
  • To disable oversubscription, perform the following operations:
    • Remove the volcano.sh/oversubscription label from the oversubscribed node.
    • Set over-subscription-resource to false.
    • Modify the configmap of the volcano scheduler named volcano-scheduler-configmap and remove the oversubscription add-on.
  • If cpu-manager-policy is set to static core binding on a node, do not assign the QoS class of Guaranteed to offline pods. If core binding is required, change the pods to online pods. Otherwise, offline pods may occupy the CPUs of online pods, causing online pod startup failures, and offline pods fail to be started although they are successfully scheduled.
  • If cpu-manager-policy is set to static core binding on a node, do not bind cores to all online pods. Otherwise, online pods occupy all CPU or memory resources, leaving a small number of oversubscribed resources.
If the label volcano.sh/oversubscription=true is configured for a node in the cluster, the oversubscription configuration must be added to the volcano add-on. Otherwise, the scheduling of oversold nodes will be abnormal. For details about the related configuration, see Table 1.
Table 1 Configuring oversubscription labels for scheduling
Oversubscription in Add-on
Oversubscription Label on Node
Scheduling
Yes
Yes
Triggered by oversubscription
Yes
No
Triggered
No
No
Triggered
No
Yes
Not triggered or failed. Avoid this configuration.
  1. Configure the volcano add-on.
    1. Use kubectl to connect to the cluster.
    2. Install the volcano add-on and add the oversubscription add-on to volcano-scheduler-configmap. Ensure that the add-on configuration does not contain the overcommit add-on. If - name: overcommit exists, delete this configuration. In addition, set enablePreemptable and enableJobStarving of the gang add-on to false and configure a preemption action.
      # kubectl edit cm volcano-scheduler-configmap -n kube-system
      apiVersion: v1
      data:
        volcano-scheduler.conf: |
          actions: "enqueue, allocate, preempt"   # Configure a preemption action.
          tiers:
          - plugins:
            - name: gang
              enablePreemptable: false
              enableJobStarving: false
            - name: priority
            - name: conformance
            - name: oversubscription
          - plugins:
            - name: drf
            - name: predicates
            - name: nodeorder
            - name: binpack
          - plugins:
            - name: cce-gpu-topology-predicate
            - name: cce-gpu-topology-priority
            - name: cce-gpu
  2. Enable the node oversubscription feature.
    A label can be configured to use oversubscribed resources only after the oversubscription feature is enabled for a node. Related nodes can be created only in a node pool. To enable the oversubscription feature, perform the following steps:
    1. Create a node pool.
    2. Choose More > Manage in the Operation column of the created node pool.
    3. In the Manage Components window that is displayed, set over-subscription-resource under kubelet to true and click OK.
  3. Set the node oversubscription label.
    The volcano.sh/oversubscription label needs to be configured for an oversubscribed node. If this label is set for a node and the value is true, the node is an oversubscribed node. Otherwise, the node is not an oversubscribed node.
    kubectl label node 192.168.0.0 volcano.sh/oversubscription=true
    An oversubscribed node also supports the oversubscription thresholds, as listed in Table 2. For example:
    kubectl annotate node 192.168.0.0 volcano.sh/evicting-cpu-high-watermark=70
    Querying the node information
    # kubectl describe node 192.168.0.0
    Roles:              <none>
    Labels:           ...
    Annotations:      ...
                      volcano.sh/evicting-cpu-high-watermark: 70
    Table 2 Node oversubscription annotations
    Name
    When the CPU usage of a node exceeds the specified value, offline job eviction is triggered and the node becomes unschedulable.
    The default value is 80, indicating that offline job eviction is triggered when the CPU usage of a node exceeds 80%.
    volcano.sh/evicting-cpu-low-watermark
    After eviction is triggered, the scheduling starts again when the CPU usage of a node is lower than the specified value.
    The default value is 30, indicating that scheduling starts again when the CPU usage of a node is lower than 30%.
    volcano.sh/evicting-memory-high-watermark
    When the memory usage of a node exceeds the specified value, offline job eviction is triggered and the node becomes unschedulable.
    The default value is 60, indicating that offline job eviction is triggered when the memory usage of a node exceeds 60%.
    volcano.sh/evicting-memory-low-watermark
    After eviction is triggered, the scheduling starts again when the memory usage of a node is lower than the specified value.
    The default value is 30, indicating that the scheduling starts again when the memory usage of a node is less than 30%.
    volcano.sh/oversubscription-types
    Oversubscribed resource type. The options are as follows:
    • CPU (oversubscribed CPU)
    • memory (oversubscribed memory)
    • cpu,memory (oversubscribed CPU and memory)
    The default value is cpu,memory.
  4. Create resources at a high- and low-priorityClass, respectively.
    cat <<EOF | kubectl apply -f -
    apiVersion: scheduling.k8s.io/v1
    description: Used for high priority pods
    kind: PriorityClass
    preemptionPolicy: PreemptLowerPriority
    value: 999999
    description: Used for low priority pods
    kind: PriorityClass
    value: -99999
    EOF
  5. Deploy online and offline jobs and configure priorityClasses for these jobs.
    The volcano.sh/qos-level label needs to be added to annotation to distinguish offline jobs. The value is an integer ranging from -7 to 7. If the value is less than 0, the job is an offline job. If the value is greater than or equal to 0, the job is a high-priority job, that is, online job. You do not need to set this label for online jobs. For both online and offline jobs, set schedulerName to volcano to enable the volcano scheduler.
    The priorities of online/online and offline/offline jobs are not differentiated, and the value validity is not verified. If the value of volcano.sh/qos-level of an offline job is not a negative integer ranging from -7 to 0, the job is processed as an online job.
    For an offline job:
    kind: Deployment
    apiVersion: apps/v1
      replicas: 4
      template:
          annotations:
            metrics.alpha.kubernetes.io/custom-endpoints: '[{"api":"","path":"","port":"","names":""}]'
            volcano.sh/qos-level: "-1"       # Offline job label
          schedulerName: volcano             # The volcano scheduler is used.
          priorityClassName: testing         # Configure the testing priorityClass.
    For an online job:
    kind: Deployment
    apiVersion: apps/v1
      replicas: 4
      template:
          annotations:
          priorityClassName: production   # Configure the production priorityClass.
  6. Run the following command to check the number of oversubscribed resources and the resource usage:
    kubectl describe node <nodeIP>
    Roles:              <none>
    Labels:           ...
    Annotations:      ...
                      volcano.sh/oversubscription-cpu: 2335
                      volcano.sh/oversubscription-memory: 341753856
    Allocatable:
      cpu:               3920m
      memory:            6263988Ki
    Allocated resources:
      (Total limits may be over 100 percent, i.e., overcommitted.)
      Resource           Requests      Limits
      cpu                 4950m (126%)  4950m (126%)
      memory             1712Mi (27%)  1712Mi (27%)
Deployment Example
The following uses an example to describe how to deploy online and offline jobs in hybrid mode.
  1. Assume that a cluster has two nodes: one oversubscribed node and one non-oversubscribed node.
    # kubectl get node
    NAME           STATUS   ROLES    AGE    VERSION
    192.168.0.173   Ready    <none>   4h58m   v1.19.16-r2-CCE22.5.1
    192.168.0.3     Ready    <none>   148m    v1.19.16-r2-CCE22.5.1
    • 192.168.0.173 is an oversubscribed node (with the volcano.sh/oversubscription=true label).
    • 192.168.0.3 is a non-oversubscribed node (without the volcano.sh/oversubscription=true label).
    # kubectl describe node 192.168.0.173
    Roles:              <none>
    Labels:             beta.kubernetes.io/arch=amd64
  2. Submit offline job creation requests. If resources are sufficient, all offline jobs will be scheduled to the oversubscribed node.
    The offline job template is as follows:
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: offline
      template:
          labels:
            app: offline
          annotations:
          containers:
            - name: container-1
              image: nginx:latest
              imagePullPolicy: IfNotPresent
              resources:
                requests:
                  cpu: 500m
                  memory: 512Mi
                limits:
                  cpu: "1"
                  memory: 512Mi
          imagePullSecrets:
            - name: default-secret
    Offline jobs are scheduled to the oversubscribed node.
    # kubectl get pod -o wide
    NAME                      READY   STATUS   RESTARTS  AGE     IP             NODE
    offline-69cdd49bf4-pmjp8   1/1    Running   0         5s    192.168.10.178   192.168.0.173
    offline-69cdd49bf4-z8kxh   1/1    Running   0         5s    192.168.10.131   192.168.0.173
  3. Submit online job creation requests. If resources are sufficient, the online jobs will be scheduled to the non-oversubscribed node.
    The online job template is as follows:
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: online
      template:
          labels:
            app: online
          containers:
            - name: container-1
              image: resource_consumer:latest
              resources:
                requests:
                  cpu: 1400m
                  memory: 512Mi
                limits:
                  cpu: "2"
                  memory: 512Mi
          imagePullSecrets:
    Online jobs are scheduled to the non-oversubscribed node.
    online-ffb46f656-4mwr6  1/1    Running   0         5s    192.168.10.146   192.168.0.3
    online-ffb46f656-dqdv2   1/1    Running   0         5s    192.168.10.67   192.168.0.3
  4. Improve the resource usage of the oversubscribed node and observe whether offline job eviction is triggered.
    Deploy online jobs to the oversubscribed node (192.168.0.173).
    apiVersion: apps/v1
    kind: Deployment
      namespace: default
      replicas: 2
      selector:
        matchLabels:
          app: online
      template:
          labels:
            app: online
           affinity:                             # Submit an online job to an oversubscribed node.
            nodeAffinity:
              requiredDuringSchedulingIgnoredDuringExecution:
                nodeSelectorTerms:
                - matchExpressions:
                  - key: kubernetes.io/hostname
                    operator: In
                    values:
                    - 192.168.0.173
          containers:
            - name: container-1
              resources:
                requests:
                  cpu: 700m
                  memory: 512Mi
                limits:
                  cpu: 700m
                  memory: 512Mi
          imagePullSecrets:
    Submit the online or offline jobs to the oversubscribed node (192.168.0.173) at the same time.
    offline-69cdd49bf4-pmjp8  1/1     Running    0      13m   192.168.10.178   192.168.0.173
    offline-69cdd49bf4-z8kxh  1/1     Running     0      13m   192.168.10.131   192.168.0.173
    online-6f44bb68bd-b8z9p  1/1     Running     0     3m4s   192.168.10.18   192.168.0.173
    online-6f44bb68bd-g6xk8  1/1     Running     0     3m12s   192.168.10.69   192.168.0.173
    Observe the oversubscribed node (192.168.0.173). You can find that oversubscribed resources exist and the CPU allocation rate exceeds 100%.
    Roles:              <none>
    Labels:              …
    Annotations:         …
                        volcano.sh/oversubscription-cpu: 2343
                        volcano.sh/oversubscription-memory: 3073653200
      cpu                    4750m (121%)  7350m (187%)
      memory                 3760Mi (61%)  4660Mi (76%)
    Increase the CPU usage of online jobs on the node. Offline job eviction is triggered.
    offline-69cdd49bf4-bwdm7  1/1    Running   0       11m   192.168.10.208  192.168.0.3
    offline-69cdd49bf4-pmjp8   0/1    Evicted    0       26m   <none>         192.168.0.173
    offline-69cdd49bf4-qpdss   1/1     Running   0       11m   192.168.10.174  192.168.0.3
    offline-69cdd49bf4-z8kxh   0/1     Evicted    0       26m   <none>        192.168.0.173
    online-6f44bb68bd-b8z9p   1/1     Running   0       24m   192.168.10.18  192.168.0.173
    online-6f44bb68bd-g6xk8   1/1     Running   0       24m   192.168.10.69  192.168.0.173
Handling Suggestions
  • After kubelet of the oversubscribed node is restarted, the resource view of the Volcano scheduler is not synchronized with that of kubelet. As a result, OutOfCPU occurs in some newly scheduled jobs, which is normal. After a period of time, the Volcano scheduler can properly schedule online and offline jobs.
  • After online and offline jobs are submitted, you are not advised to dynamically change the job type (adding or deleting annotation volcano.sh/qos-level: "-1") because the current kernel does not support the change of an offline job to an online job.
  • CCE collects the resource usage (CPU/memory) of all pods running on a node based on the status information in the cgroups system. The resource usage may be different from the monitored resource usage, for example, the resource statistics displayed by running the top command.
  • You can add oversubscribed resources (such as CPU and memory) at any time.
    You can reduce the oversubscribed resource types only when the resource allocation rate does not exceed 100%.
  • If an offline job is deployed on a node ahead of an online job and the online job cannot be scheduled due to insufficient resources, configure a higher priorityClass for the online job than that for the offline job.
  • If there are only online jobs on a node and the eviction threshold is reached, the offline jobs that are scheduled to the current node will be evicted soon. This is normal.
