Help Center/
Cloud Container Engine/
Drawer/
Configuration Reference/
Pods/
Pod Template/
Online and Offline Service Deployment Priority
Updated on 2025-11-11 GMT+08:00
A value less than 0 specifies a low-priority task, which is, an offline job. A value greater than or equal to 0 specifies a high-priority task, which is, an online job.
Value Range
An integer from –7 to 7
Default Value
None
Modifiable
Yes
