Help Center/ Cloud Container Engine/ Drawer/ Configuration Reference/ Nodes/ kubelet/ Maximum Number of Container Log Files
Updated on 2025-06-13 GMT+08:00
It determines how many log files can be stored in a Docker container. It helps control disk usage and prevents old logs from taking up too much space.
If it is set to a small value, important logs may be lost. If it is set to a large value, too much disk space may be occupied.
Value Range
2–100
Default Value
20
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
Suggestions
Configure this parameter based on the frequency and size of the application logs that are generated and based on available disk space. Unless otherwise specified, keep the default settings.
