Maximum Number of Concurrent Requests for Downloading an Image at a Time
It specifies the maximum number of concurrent requests for downloading an image at a time.
If this parameter is set to a large value, the network performance of other services on the node may be affected or the disk I/O and CPU usage may increase.
Value Range
1–20
Default Value
3
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Modify the settings based on the node network bandwidth. Unless otherwise specified, keep the default settings.
