Updated on 2025-11-11 GMT+08:00
Eviction Grace Periods
It provides a set of eviction grace periods. A pod will be evicted only when the soft eviction thresholds are met within a certain grace period. The parameter is used together with the soft eviction thresholds.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
