Help Center/Cloud Container Engine/Drawer/Configuration Reference/Nodes/kubelet Settings/Hard Eviction
Updated on 2025-11-11 GMT+08:00
Hard Eviction
It controls a set of eviction thresholds. If these thresholds are met, a pod will be evicted from the node. The following thresholds can be configured:
- memory.available: the available memory on the node
- nodefs.available: the percentage of the available capacity of the filesystem used by kubelet
- nodefs.inodesFree: the percentage of available inodes in the filesystem used by kubelet
- imagefs.available: the percentage of the available capacity of the filesystem that container runtimes use to store resources such as images
- imagefs.inodesFree: the percentage of available inodes in the filesystem that container runtimes use to store resources such as images
- pid.available: the percentage of allocatable PIDs reserved for pods
Value Range
None
Default Value
- memory.available: 100Mi
- nodefs.available: 10%
- nodefs.inodesFree: 5%
- imagefs.available: 15%
Modifiable
Yes
Scope
CCE standard and Turbo clusters
