Maximum Number of Concurrent Non-Modification API Calls
It controls the maximum number of concurrent non-modification requests, which are mainly GET and LIST requests that a server can receive. Any requests that exceeding the specified value will be rejected by the server.
Manual configuration is no longer supported since clusters 1.21. The value is automatically specified based on the cluster scale.
- 400 for clusters with 50 or 200 worker nodes
- 1000 for clusters with 1,000 worker nodes
- 2000 for clusters with 2,000 worker nodes
The value 0 specifies that there is no limitation on the maximum number of concurrent non-modification requests.
Value Range
Greater than or equal to 0
Default Value
Modifiable
No. The system configuration cannot be modified.
Scope
CCE standard and CCE Turbo clusters
Suggestions
Keep the default.
If the parameter is set to a large value, the cluster may be overloaded.
