HPA Scale-in Stabilization Window
HPA uses the maximum recommended replica count from the configured stabilization window. This parameter dampens short-lived load dips, eliminating needless pod churn.
For details, see the official documentation.
Value Range
Valid time format strings
Default Value
5m0s
Suggestions
Raise the window to stop rapid scale-in/scale-out caused by transient dips. This improves system stability.
Possible Risks
If the stabilization window is too short, HPA will over-react to brief load dips and repeatedly create and delete pods. If it is too long, HPA will keep unneeded pods alive after real demand has dropped, wasting resources. If it exceeds the maximum length supported (153,722,867 minutes), HPA may fail to start. When HPA restarts, the scale-in stabilization timer resets.
