Toleration Time for Nodes in NotReady State
If a node becomes unavailable, pods running on the node are evicted automatically after the tolerance time elapses. The default value is 300.
It specifies the default tolerance time, and the configuration takes effect for all pods by default. You can configure different tolerance time for pods.
Value Range
No strong verification
Default Value
300
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Unless otherwise specified, keep the default settings.
If the specified tolerance time is too short, pods may be frequently migrated in scenarios like a network jitter. If the specified tolerance time is too long, services may be interrupted during this period after the node is faulty.
