Mask Bits of the Fixed IP Address Pool of Container Networks
It controls the number of mask bits of the fixed IP address pool of the container networks. It is supported only by the VPC network model (vpc-router).
The parameter determines the maximum number of IP addresses that can be assigned to containers on a node. This, along with the maxPods setting during node creation, determines the maximum number of pods that can be created on a node.
Value Range
24 to 28
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
