Elastic Protection Bandwidth
Basic protection bandwidth can be used to defend against attacks (prepaid).
Elastic protection bandwidth is the maximum available defense bandwidth (postpaid). When the attack peak exceeds the basic protection bandwidth, the system uses the elastic protection bandwidth to ensure service continuity.
Protection Capacity
The protection capacity equals the basic or elastic protection bandwidth, whichever is higher.
If the elastic protection bandwidth equals the basic protection bandwidth, elastic protection does not take effect.
Example 1: If the basic protection bandwidth is 10 Gbit/s and the elastic protection bandwidth is 10 Gbit/s, elastic protection does not take effect, and the protection capacity is 10 Gbit/s.
Example 2: If the basic protection bandwidth is 10 Gbit/s and the elastic protection bandwidth is 20 Gbit/s, elastic protection takes effect when the attack traffic exceeds 10 Gbit/s, and the protection capacity is 20 Gbit/s.
Example 3: If the basic protection bandwidth is 10 Gbit/s and the elastic protection bandwidth is 20 Gbit/s, elastic protection takes effect when the attack traffic exceeds 20 Gbit/s, and the protection capacity is 20 Gbit/s.
Billing Principles
If the peak attack traffic is less than or equal to the basic protection bandwidth, no extra fees will be charged.
It is billed by day, postpaid. It is billed based on the DDoS attack peaks on the current day. The billing rules are as follows:
- Peak DDoS attack traffic on the current day ≤ Basic protection bandwidth: No elastic protection bandwidth fee is generated.
- Basic protection bandwidth < Peak DDoS attack traffic on the current day < Elastic protection bandwidth: Elastic protection bandwidth fees will be incurred.
- Peak DDoS attack traffic on the current day ≥ Elastic protection bandwidth: Elastic protection bandwidth fees will be incurred.
The elastic protection bandwidth usage in different scenarios is calculated as follows:
- Basic protection bandwidth < Peak attack traffic < Elastic protection bandwidth: Elastic protection bandwidth usage (billed) = Peak attack traffic on the current day – Basic protection bandwidth
- Peak attack traffic ≥ Elastic protection bandwidth: Elastic protection bandwidth usage (billed) = Elastic protection bandwidth – Basic protection bandwidth
Billing Example
For example, for three AAD instances, the basic protection bandwidth is 20 Gbit/s, and the elastic protection bandwidth is 100 Gbit/s. If the three instances are under multiple DDoS attacks on the same day, the billing rules of the elastic protection bandwidth are as follows:
| Instance | Attack Traffic Peak | Fees Generated | Description |
| Instance A | 20 Gbit/s | No | If the peak attack traffic does not exceed the basic protection bandwidth, no elastic bandwidth fee is generated. |
| Instance B | 80 Gbit/s | Yes | Billed elastic bandwidth: 80 Gbit/s - 20 Gbit/s = 60 Gbit/s. |
| Instance C | 120 Gbit/s | Yes | 120 Gbit/s is greater than the elastic protection bandwidth 100 Gbit/s. Billed protection bandwidth: 100 Gbit/s - 20 Gbit/s = 80 Gbit/s. |
