Listing Stacks
Function
This API is used to query a stack list.
URI
GET /v2/stacks?project_id={project_id}
Parameter |
Mandatory |
Description |
project_id |
Yes |
Project to which the stack belongs. This parameter is mandatory for common user queries. The value must be 1 to 64 characters long. |
labels |
No |
Label of the stack to be queried. The format is "key1=value1,key2=value2". The label names and values must meet the requirements of the labels field in Table 1. |
dsl_version |
No |
DSL version of the template. The stack of the corresponding version can be queried. Only huaweicloud _tosca_version_1_0 is supported. By default, this parameter is left blank. |
template_id |
No |
Template ID. The stack that uses the specified template ID can be queried. This parameter cannot coexist with template_name. |
template_name |
No |
Template name. The stack that uses the specified template name can be queried. This parameter cannot coexist with template_id. |
template_version |
No |
Template version. The stack that uses the specified template version is queried. You need to specify template_name at the same time. |
include_periodic_res |
No |
Stacks billed in the yearly/monthly mode are queried. |
include_stack |
No |
name |
No |
The stack that uses the specified name is queried. |
status |
No |
Stack status.
Request
N/A
Response message.
- Response Parameters
A response parameter is a stack structure list or response structure.
- The stack structure list is returned when the query is successful.
- The failure response structure is returned when the query fails.
For the stack structure, see Table 2. For the failure response structure, see Table 5.
Table 2 Response Parameters Parameter
Type
[Array element]
Array of objects
Each element indicates the stack details. For details, see Table 2.
- Success response example
Only a single stack structure is provided here. The returned URL is JSONArray([{"name": "stack1", ...}, {"name": "stack2", ...}]).
{ "force": false, "guid": "6c2dc1bc-66cc-11e7-8a31-0255ac101c16", "namespace": "csc-system", "project_id": "3de3c020647e447fb9c9dbe1f0fc8b85", "cluster_name": "cluster01", "cluster_id": "d019ddfa-61e2-11e7-80ba-0255ac100705", "domain_id": "c952eaaa5bdc43668d31aff2bb74a72d", "name": "b-lss-f98q0", "description": "", "status": "Running", "template_id": "6307541e-11e9-8d57-0682-0a0ab82e8450", "previous_template_id": "", "template_name": "paasconsole", "healthy": true, "healthy_message": "", "inputs_json": "{\"app_path\":\"/\",\"container_port\":18081,\"custom_tag_key0\":\"netype\",\"custom_tag_val0\":\"com.huawei.itpaas.platformservice.ncss\",\"extend_info\":\"{}\",\"image_name\":\"10.101.248.47:20202/aos-team/cam-default/dw_broker_lss_suse11sp3:v600r001c11\",\"pod_name\":\"b-lss-f98q0\",\"role_name\":\"manage\",\"secret_name\":\"default-ingress-ssl\",\"service_guid\":\"beef926a-e170-0419-c220-16d90bce9951\",\"sso_info\":\"{\\\"iam_external_domain\\\":\\\"10.101.248.93\\\",\\\"iam_external_addr\\\":\\\"10.101.248.93\\\",\\\"iam_internal_ip\\\":\\\"iam.kube-system.svc.cluster.local\\\",\\\"iam_port\\\":\\\"31943\\\"}\",\"volume_container_path\":\"/home/agentlib/uniagentconf\",\"volume_host_path\":\"/home/agentlib/uniagentconf\"}", "previous_inputs_json": "", "create_at": "2017-07-12T06:36:23Z", "update_at": "2017-07-12T06:36:39Z", "labels": "", "object": { "metadata": { "name": "b-lss-f98q0", "namespace": "3de3c020647e447fb9c9dbe1f0fc8b85", "selfLink": "/apis/paas/v1alpha1/namespaces/3de3c020647e447fb9c9dbe1f0fc8b85/stacks/b-lss-f98q0", "uid": "6c2dc1bc-66cc-11e7-8a31-0255ac101c16", "resourceVersion": "1442425", "creationTimestamp": "2017-07-12T06:36:23Z", "labels": { "stackname": "b-lss-f98q0" }, "annotations": { "cluster-id": "d019ddfa-61e2-11e7-80ba-0255ac100705", "namespace": "csc-system", "paas-iam.alpha.kubernetes.io/domain-id": "c952eaaa5bdc43668d31aff2bb74a72d", "stack.kubernetes.io/revision": "1" } }, "spec": { "selector": { "matchLabels": { "stackname": "b-lss-f98q0" } }, "template": { "type": "Aos", "data": "******" } }, "status": { "phase": "CreateSucceeded", "elementStatuses": { "paas-console-app": { "runtimeProperties": { "CfeCluster": "{\"clusterID\":\"d019ddfa-61e2-11e7-80ba-0255ac100705\",\"namespace\":\"csc-system\"}", "ConfigMap": "{\"selfLink\":\"/api/v1/namespaces/csc-system/configmaps/b-lss-f98q0\",\"name\":\"b-lss-f98q0\",\"id\":\"7248cfe7-66cc-11e7-9a88-286ed489ceaa\"}", "Deployment": "{\"selfLink\":\"/apis/extensions/v1beta1/namespaces/csc-system/deployments/b-lss-f98q0\",\"name\":\"b-lss-f98q0\",\"id\":\"7253bff2-66cc-11e7-9a88-286ed489ceaa\"}", "Ingress": "{\"selfLink\":\"/apis/extensions/v1beta1/namespaces/csc-system/ingresses/b-lss-f98q0\",\"annotations\":{\"ingress.beta.kubernetes.io/role\":\"manage\",\"ingress.beta.kubernetes.io/type\":\"external\",\"ingress.kubernetes.io/external-address\":\"10.101.204.188:30283\",\"ingress.kubernetes.io/external-ssl-address\":\"10.101.204.188:30282\"},\"rules\":[{\"host\":\"b-lss-f98q0-csc-system.10.101.204.188.xip.io\",\"http\":{\"paths\":[{\"path\":\"/\",\"backend\":{\"serviceName\":\"b-lss-f98q0\",\"servicePort\":32158}}]}}]}", "Service": "{\"selfLink\":\"/api/v1/namespaces/csc-system/services/b-lss-f98q0\",\"type\":\"NodePort\",\"ports\":[{\"name\":\"\",\"protocol\":\"TCP\",\"port\":18081,\"targetPort\":18081,\"nodePort\":32158}],\"selector\":{\"app\":\"b-lss-f98q0\",\"stack-name\":\"b-lss-f98q0\"},\"clusterIP\":\"10.247.248.87\",\"ExternalName\":\"\",\"sessionAffinity\":\"None\"}" } } }, "lastExecutionStatus": { "actionName": "create", "progress": 100, "objectStatus": { "phase": "Succeeded", "updateAt": "2017-07-12T06:36:37Z" }, "subObjectStatuses": { "host-dir": { "phase": "Succeeded", "updateAt": "2017-07-12T06:36:23Z" }, "paas-console": { "phase": "Succeeded", "updateAt": "2017-07-12T06:36:23Z" }, "paas-console-app": { "phase": "Succeeded", "updateAt": "2017-07-12T06:36:36Z" } } } } }, "health": { "message": "", "healthy": true } }
- Error response example
{ "message": "Internal error.please check the error log and handle it.", "code": "02000051", "extend": "" }
Status Code
- Normal
Table 3 Status Code Status Code
200
Querying the stack list is successful.
- Abnormal
Table 4 Status Code Status Code
500
The server fails to process the request due to an unexpected condition.
