Help Center/ Cloud Service Engine/ User Guide(Ally Region)/ ServiceComb Engines/ Viewing Microservice Running Metrics Through the Microservice Dashboard
Updated on 2025-12-30 GMT+08:00
You can view metrics related to microservices through the dashboard in real time. Based on abundant and real-time dashboard data, you can take corresponding governance actions for microservices.
Restrictions
  • This function is supported by ServiceComb engine 1.x and 2.4.0 and later versions.
  • If a microservice application is deployed on ServiceStage, you need to configure the microservice engine during application deployment. The application automatically obtains the service registry and discovery address, configuration center address, and dashboard address. You do not need to configure the monitor address.
  • If the microservice application is locally started and registered with the ServiceComb engine, manually configure the monitor address before using the dashboard.
  • When the Spring Cloud Huawei framework is used for access, the median latency, 90th latency, and 99th latency cannot be viewed on the dashboard.
  1. Click the target engine.
  2. Choose Dashboard.
    • For engines with security authentication disabled, go to 4.
    • For engines with security authentication enabled, if the login user is the user imported in Importing an IAM Account, go to 4. For other users, go to 3.
  3. In the displayed Security Authentication dialog box, enter the account name and password, and click OK.
  4. On the Dashboard page, select the target application. Enter a microservice name in the search box to search for the microservice. The running metrics of the microservice are displayed.
    Click View Diagram to view the description of operating metrics.
  5. Select a sorting order to sort the filtered microservices.
