Help Center/
Cloud Service Engine/
User Guide(Ally Region)/
ServiceComb Engines/
Managing ServiceComb Engines/
Deleting a ServiceComb Engine
Updated on 2025-12-30 GMT+08:00
You can delete a ServiceComb engine if it is no longer used. You can delete ServiceComb engines in the following states:
- Available
- Unavailable
- Creation failed
- Resizing failed
- Upgrade failed
- Unknown
Restrictions
- Deleted engines cannot be restored. Exercise caution when performing this operation.
- For engine 1.x, if the cse_admin_trust agency is missing, deleting the engine will cause residual DNS, VPC, and security group resources on the tenant side. You need to delete them by yourself.
- Click Delete in the Operation column of the target engine. Alternatively, click the target engine and click Delete in the ServiceComb Engine Information area.
- In the displayed dialog box, enter DELETE and click OK.
If the deletion fails, click Force Delete.
Parent topic: Managing ServiceComb Engines
