Updated on 2026-01-09 GMT+08:00
substring_index
This function is used to truncate the string before the count separator of str. If the value of count is positive, the string is truncated from the left. If the value of count is negative, the string is truncated from the right.
Syntax
substring_index(string <str>, string <separator>, int <count>)
Parameters
Table 1 Parameters
Mandatory
Type
str
Yes
STRING
String to be truncated
separator
Yes
STRING
Separator of the STRING type
count
No
INT
Position of the delimiter
Return Values
The return value is of the STRING type.
If the value of any input parameter is NULL, NULL is returned.
Example Code
The value hello.world is returned.
SELECT substring_index('hello.world.people', '.', 2);
The value world.people is returned.
select substring_index('hello.world.people', '.', -2);
