Help Center/ Data Lake Insight/ SQL Syntax Reference (Ally Region)/ Spark SQL Syntax Reference/ Built-in Functions/ Date Functions/ current_timestamp
Updated on 2026-01-09 GMT+08:00
current_timestamp
This function is used to return the current timestamp.
Syntax
current_timestamp()
Parameters
None
Return Values
The return value is of the TIMESTAMP type.
Example Code
The value 1692002816300 is returned.
select current_timestamp();
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
