Updated on 2026-01-09 GMT+08:00
abs
This function is used to calculate the absolute value of an input parameter.
Syntax
abs(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE or INT type.
If the value of a is NULL, NULL is returned.
Example Code
The value NULL is returned.
select abs(null);
The value 1 is returned.
select abs(-1);
The value 3.1415926 is returned.
select abs(-3.1415926);
