Help Center/
Virtual Private Cloud/
User Guide (ME-Abu Dhabi Region)/
FAQ/
VPC Peering Connections/
Can a VPC Peering Connection Connect VPCs in Different Regions?
Updated on 2024-04-18 GMT+08:00
A VPC peering connection only can connect VPCs in the same region.
Figure 1 shows an application scenario of VPC peering connections.
- There are two VPCs (VPC-A and VPC-B) in region A that are not connected.
- Service servers (ECS-A01 and ECS-A02) are in VPC-A, and database servers (RDS-B01 and RDS-B02) are in VPC-B. The service servers and database servers cannot communicate with each other.
- You need to create a VPC peering connection (peering-AB) between VPC-A and VPC-B so the service servers and database servers can communicate with each other.
Parent topic: VPC Peering Connections
