Creating a Custom Policy
Custom policies can be created to supplement the system-defined policies of BCS.
You can create custom policies in either of the following ways:
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Edit policies from scratch or based on an existing policy in JSON format.
For details, see Creating a Custom Policy. The following section contains examples of common BCS custom policies.
- On the management console homepage, click Identity and Access Management.
- In the navigation pane, choose Permissions > Policies/Roles and click Create Custom Policy.
- On the Create Custom Policy page, set the policy name, view, content, and description, then click OK.
- Policy Name: Enter a custom policy name, for example, "partial BCS permissions".
- Policy View: Select JSON.
- Policy Content: Enter the policy content based on the template.
For example, copy the following content to grant permissions for instance, channel, and member management.
{ "Version": "1.1", "Statement": [ { "Effect": "Allow", "Action": [ "bcs:blockchains:list", "bcs:channels:list", "bcs:members:list" ] } ] }Table 1 Policy content parameters Parameter
Setting
Version
Policy version
Fixed to 1.1.
Statement
Effect
Whether the actions are allowed
- Allow
- Deny
Action
Operations to be performed on BCS
Each action name is in the format of Service name:Resource type:Operation and cannot be customized. Table 2 lists the fine-grained permissions supported by BCS. After you set any action, the permissions for the action will be granted to the IAM user.
Table 2 Action description Related Action
Action Description
bcs:peer:get
Querying peers
bcs:notifications:list
Managing notifications
bcs:blockchain:get
Querying BCS service details
bcs:notification:get
Querying notification details
bcs:membertopo:get
Querying topology information
bcs:contract:get
Viewing contract details
bcs:member:get
Querying member details
bcs:plugin:get
Querying add-on details
bcs:dashboard:get
Viewing the dashboard
bcs:sdkcfg:post
Downloading SDK configurations
bcs:blockchainondemand:create
Creating BCS services
bcs:blockchain:awakehibernate
Freezing or unfreezing instances
bcs:notification:put
Processing notifications
bcs:eip:put
Updating EIPs
bcs:plugin:delete
Deleting add-ons
bcs:taskserver:create
Creating the taskserver add-on
bcs:member:put
Inviting tenants
bcs:notification:delete
Deleting notifications
bcs:channel:create
Creating channels
bcs:member:delete
Deleting members
bcs:channel:put
Adding peers to channels
bcs:blockchain:upgrade
Upgrading or rolling back BCS services
bcs:cert:post
Downloading certificates
bcs:blockchain:delete
Deleting BCS services
bcs:channel:delete
Deleting a channel
bcs:members:list
Listing members
bcs:channels:list
Listing channels
bcs:plugins:list
Listing add-ons
Listing BCS services
bcs:contracts:list
Listing contracts
bcs:restapi:create
Creating the baas-restapi add-on
bcs:cluster:post
Cluster-related operations
