Lifecycle
The lifecycle of an instance in an AS group starts when it is created and ends when it is removed from the AS group.
Status |
Sub-status |
Status Description |
Trigger Condition |
Initial |
N/A |
The instance has not been added to an AS group. |
The status of an instance is changed to Adding to AS group when either of the following operations is performed:
Adding to AS group |
Add an instance. |
When trigger condition 1 is met, AS adds the instance to expand the AS group capacity. |
(Optional) Associate the instance with a load balancing listener. |
When trigger condition 1 is met, AS associates the created instance with the load balancing listener. |
Enabled |
N/A |
The instance is added to the AS group and starts to process service traffic. |
The instance status is changed from Enabled to Removing from AS group when any of the following operations are performed:
Removing from AS group |
(Optional) Disassociate the instance from the load balancing listener. |
When trigger condition 3 is met, the AS group starts to reduce resources and disassociate the instance from the load balancing listener. |
Remove the instance. |
After the instance is unbound from the load balancing listener, it is removed from the AS group. |
Removed |
N/A |
The instance lifecycle in the AS group ends. |
N/A |
Instances are added to an AS group manually or through a scaling action. Then, they go through the Adding to AS group, Enabled, and Removing from AS group statuses, and are finally removed from the AS group.
Status |
Sub-status |
Trigger Description |
Initial |
N/A |
Add an instance. |
Wait (Adding to AS group) |
N/A |
The lifecycle hook suspends the instance that is being added to the AS group and sets the instance to be in waiting state. |
The instance status is changed from Wait (Adding to AS group) to Adding to AS group when either of the following operations is performed:
When trigger condition 3 is met, AS associates the instance with the load balancing listener. |
Enabled |
N/A |
When trigger condition 5 is met, the AS group starts to reduce resources and disassociate the instance from the load balancing listener. |
Wait (Removing from AS group) |
N/A |
The lifecycle hook suspends the instance that is being removed from the AS group and sets the instance to be in waiting state. |
The instance status is changed from Wait (Removing from AS group) to Removing from AS group when either of the following operations is performed:
When trigger condition 7 is met, AS removes the instance from the AS group. |
Removed |
N/A |
N/A |
