RESTORE
Function
This command restores a Delta table to an earlier state, supporting restoration to a previous version number or timestamp.
Syntax
Restore a Delta table to the state at a specific point in time:
RESTORE [TABLE] [database_name.]table_name|DELTA.`obs_path`
[TO] TIMESTAMP AS OF timestamp_expression
Restore a Delta table to the state at a specific historical version:
[TO] VERSION AS OF version_code
Parameter Description
| Parameter | Description |
| database_name | Name of the database, consisting of letters, numbers, and underscores (_) |
| table_name | Name of the table in the database, consisting of letters, numbers, and underscores (_) |
| obs_path | OBS path, indicating the storage location of the Delta table |
| timestamp_expression | Timestamp, which cannot be later than the current time, formatted as yyyy-MM-ddTHH:mm:ss.SSS |
| version_code | Version number in the query result in version 1.3.1 |
Required Permissions
- SQL permissions
| Permission Description |
| UPDATE permission on a table |
- Fine-grained permission: dli:table:update
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Example
RESTORE delta_table0 TO TIMESTAMP AS OF '2020-10-18 22:15:12.013'; RESTORE delta.`obs://bucket_name/db0/delta_table0` VERSION AS OF 2;
System Response
You can view command execution results in the driver log or on the client.
