CREATE TABLE AS SELECT
Function
This command creates a Hudi table by specifying a list of fields with table attributes.
Syntax
CREATE[ OR REPLACE] TABLE [ IF NOT EXISTS] [database_name.]table_name|DELTA.`obs://bucket_name/tbl_path`
USING DELTA
[ COMMENT table_comment ]
[ PARTITIONED BY (partColumnList) ]
[ LOCATION location_path]
[ AS query_statement ]
Parameter Description
Parameter |
Description |
database_name |
Name of the database, consisting of letters, numbers, and underscores (_) |
table_name |
Name of the table in the database, consisting of letters, numbers, and underscores (_) |
bucket_name |
OBS bucket name |
tbl_path |
Storage location of the Delta table in the OBS bucket |
using |
Parameter delta, defines and creates the Delta table |
table_comment |
Description of the table |
location_path |
Storage location of the Delta table. In the current version, it must be specified when a Delta table is created based on the table name and can only support OBS paths. Specifying this path creates the Delta table as a foreign table. |
query_statement |
SELECT statement |
Required Permissions
- SQL permissions
Table 2 Permissions required for executing CREATE TABLE AS SELECT Permission Description
CREATE_TABLE permission on the database
SELECT permission to query a table
- Fine-grained permissions: dli:database:createTable and dli:table:select
- Metadata services provided by LakeFormation. Refer to the LakeFormation documentation for details on permission configuration.
Examples
- Create a partitioned table.
create table if not exists delta_table0 using delta partitioned by (dt) location 'obs://bucket_name0/db0/delta_table0' as select 1 as id, 'a1' as name, 10 as price, 1000 as dt;
- Create a non-partitioned table.
create table if not exists delta_table0 using delta location 'obs://bucket_name0/db0/delta_table0' as select 1 as id, 'a1' as name, 10 as price; create table delta.`obs://bucket_name0/db0/delta_table0` using delta partitioned by (part_col1, part_col2) as select id,name,year,class_name from table1 where part_col1=2024;
