Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Node/ Node Running/ How Do I Fix an Abnormal Container or Node Due to No Thin Pool Disk Space?
Symptom
When the disk space of a thin pool on a node is about to be used up, the following exceptions occasionally occur:
Files or directories fail to be created in the container, the file system in the container is read-only, the node is tainted disk-pressure, or the node is unavailable.
You can run the docker info command on the node to view the used and remaining thin pool space to locate the fault. The following figure is an example.
Possible Cause
When Docker device mapper is used, although you can configure the basesize parameter to limit the size of the /home directory of a single container (to 10 GB by default), all containers on the node still share the thin pool of the node for storage. They are not completely isolated. When the sum of the thin pool space used by certain containers reaches the upper limit, other containers cannot run properly.
In addition, after a file is deleted in the /home directory of the container, the thin pool space occupied by the file is not released immediately. Therefore, even if basesize is set to 10 GB, the thin pool space occupied by files keeps increasing until 10 GB when files are created in the container. The space released after file deletion will be reused only after a while. If the number of service containers on the node multiplied by basesize is greater than the thin pool space size of the node, there is a possibility that the thin pool space has been used up.
Solution
When the thin pool space of a node is used up, some services can be migrated to other nodes to quickly recover services. But you are advised to use the following solutions to resolve the root cause:
Solution 1:
Properly plan the service distribution and data plane disk space to avoid the scenario where the number of service containers multiplied by basesize is greater than the thin pool size of the node. To expand the thin pool size, perform the following operations:
  1. Expand the capacity of a data disk on the EVS console.
    Only the storage capacity of EVS disks can be expanded. You need to perform the following operations to expand the capacity of logical volumes and file systems.
  2. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Nodes. In the right pane, click the Nodes tab, locate the row containing the target node, and choose More > Sync Server Data in the Operation column.
  3. Log in to the target node.
  4. Run lsblk to view the block device information of the node.
    A data disk is divided depending on the container storage Rootfs:
    Overlayfs: No independent thin pool is allocated. Image data is stored in dockersys.
    1. Check the disk and partition space of the device.
      # lsblk
      NAME                MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
      sda                   8:0    0   50G  0 disk
      └─sda1                8:1    0   50G  0 part /
      sdb                   8:16   0  150G  0 disk      # The data disk has been expanded to 150 GiB, but 50 GiB space is free.
      ├─vgpaas-dockersys  253:0    0   90G  0 lvm  /var/lib/containerd
      └─vgpaas-kubernetes 253:1    0   10G  0 lvm  /mnt/paas/kubernetes/kubelet
    2. Expand the disk capacity.
      Add the new disk capacity to the dockersys logical volume used by the container engine.
      1. Expand the PV capacity so that LVM can identify the new EVS capacity. /dev/sdb specifies the physical volume where dockersys is located.
        pvresize /dev/sdb
        Information similar to the following is displayed:
        Physical volume "/dev/sdb" changed
        1 physical volume(s) resized or updated / 0 physical volume(s) not resized
      2. Expand 100% of the free capacity to the logical volume. vgpaas/dockersys specifies the logical volume used by the container engine.
        lvextend -l+100%FREE -n vgpaas/dockersys
        Size of logical volume vgpaas/dockersys changed from <90.00 GiB (23039 extents) to 140.00 GiB (35840 extents).
        Logical volume vgpaas/dockersys successfully resized.
      3. Adjust the size of the file system. /dev/vgpaas/dockersys specifies the file system path of the container engine.
        resize2fs /dev/vgpaas/dockersys
        Filesystem at /dev/vgpaas/dockersys is mounted on /var/lib/containerd; on-line resizing required
        old_desc_blocks = 12, new_desc_blocks = 18
        The filesystem on /dev/vgpaas/dockersys is now 36700160 blocks long.
    3. Check whether the capacity has been expanded.
      # lsblk
      ├─vgpaas-dockersys  253:0    0   140G  0 lvm  /var/lib/containerd
Solution 2:
Create and delete files in service containers in the local storage (such as emptyDir and hostPath) or cloud storage directory mounted to the container. Such files do not occupy the thin pool space.
Solution 3:
If the OS uses OverlayFS, services can be deployed on such nodes to prevent the problem that the disk space occupied by files created or deleted in the container is not released immediately.
