هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Networking/ Network Planning/ How Can I Configure a Security Group Rule in a Cluster?
CCE is a universal container platform. Its default security group rules apply to common scenarios. When a cluster is created, a security group is automatically created for the master nodes and worker nodes, separately. The security group name of the master nodes is {Cluster name}-cce-control-{Random ID}, and the security group name of the worker nodes is {Cluster name}-cce-node-{Random ID}. If a CCE Turbo cluster is used, an additional ENI security group named {Cluster name}-cce-eni-{Random ID} will be created.
You can modify the security group rules on the VPC console as required. (Log in to the management console, choose Service List > Networking > Virtual Private Cloud. On the page displayed, choose Access Control > Security Groups in the navigation pane, locate the corresponding security groups, and modify their rules.)
The default security group rules of the clusters using different networks are as follows:
NOTICE:
  • Modifying or deleting security group rules may affect cluster running. Exercise caution when performing this operation. If you need to modify security group rules, do not modify the rules of the port on which CCE running depends.
  • When adding a new security group rule to a cluster, ensure that the new rule does not conflict with the original rules. Otherwise, the original rules may become invalid, affecting the cluster running.
Security Group Rules of a Cluster Using a VPC Network
Node security group
A security group named {Cluster name}-cce-node-{Random ID} is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 1.
Table 1 Default ports in the security group for the worker nodes that use a VPC network
Direction
Port
Default Source Address
Modifiable
Modification Suggestion
Inbound rules
All UDP ports
VPC CIDR block
Allow access between worker nodes and between worker nodes and the master nodes.
No
N/A
All TCP ports
All ICMP ports
Security group of master nodes
Allow master nodes to access worker nodes.
No
N/A
TCP port range: 30000 to 32767
All IP addresses: 0.0.0.0/0
Allow access from NodePort.
Yes
These ports must permit requests from VPC, container, and ELB CIDR blocks.
UDP port range: 30000 to 32767
All
Container CIDR block
Allow containers in a cluster to access nodes.
No
N/A
All
Node security group
Access outside the security group of the worker nodes is restricted, but mutual access between instances in the security group of the worker nodes is not restricted.
No
N/A
TCP port 22
Allow SSH access to ECSs.
Recommended
N/A
Outbound rule
All
Allow traffic on all ports by default. You are advised to retain this setting.
Yes
If you want to harden security by allowing traffic only on specific ports, remember to allow such ports. For details, see Hardening Outbound Rules.
A security group named {Cluster name}-cce-control-{Random ID} is automatically created for the master nodes in a cluster. For details about the default ports, see Table 2.
Table 2 Default ports in the security group for the master nodes that use a VPC network
Direction
Port
Modifiable
Inbound rules
TCP port 5444
VPC CIDR block
Allow access from kube-apiserver, which provides lifecycle management for Kubernetes resources.
No
N/A
TCP port 5444
TCP port 9443
VPC CIDR block
Allow the network add-on of the worker nodes to access master nodes.
No
N/A
TCP port 5443
Allow kube-apiserver of the master nodes to listen to the worker nodes.
Recommended
The port must allow traffic from the CIDR blocks of the VPC, container, and the management plane of the hosted service mesh.
TCP port 8445
VPC CIDR block
Allow the storage add-on of worker nodes to access master nodes.
No
N/A
All
Access outside the security group of the master nodes is restricted, but mutual access between instances in the security group of the master nodes is not restricted.
No
N/A
Outbound rule
All
No
N/A
Security Group Rules of a Cluster Using the Tunnel Network
Node security group
A security group named {Cluster name}-cce-node-{Random ID} is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 3.
Table 3 Default ports in the security group for the worker nodes that use a tunnel network
Direction
Port
Modifiable
Inbound rules
UDP port 4789
Allow access between containers.
No
N/A
TCP port 10250
CIDR block of master nodes
Allow master nodes to access kubelet on worker nodes, for example, by running kubectl exec {pod}.
No
N/A
Yes
TCP port 22
Recommended
N/A
All
Node security group
No
N/A
Outbound rule
All
Yes
A security group named {Cluster name}-cce-control-{Random ID} is automatically created for the master nodes in a cluster. For details about the default ports, see Table 4.
Table 4 Default ports in the security group for the master nodes that use a tunnel network
Direction
Port
Modifiable
Inbound rules
UDP port 4789
No
N/A
TCP port 5444
VPC CIDR block
No
N/A
TCP port 5444
TCP port 9443
VPC CIDR block
No
N/A
TCP port 5443
Recommended
TCP port 8445
VPC CIDR block
No
N/A
All
No
N/A
Outbound rule
All
No
N/A
Security Group Rules of a CCE Turbo Cluster Using the Cloud Native 2.0 Network
Node security group
A security group named {Cluster name}-cce-node-{Random ID} is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 5.
Table 5 Default ports in the security group for the worker nodes in a CCE Turbo cluster
Direction
Port
Modifiable
Inbound rules
TCP port 10250
No
N/A
Yes
TCP port 22
Recommended
N/A
All
Node security group
No
N/A
All
Container subnet CIDR block
No
N/A
Outbound rule
All
Yes
A security group named {Cluster name}-cce-control-{Random ID} is automatically created for the master nodes in a cluster. For details about the default ports, see Table 6.
Table 6 Default ports in the security group for the master nodes in a CCE Turbo cluster
Direction
Port
Modifiable
Inbound rules
TCP port 5444
No
N/A
TCP port 5444
VPC CIDR block
No
N/A
TCP port 9443
VPC CIDR block
No
N/A
TCP port 5443
Recommended
TCP port 8445
VPC CIDR block
No
N/A
All
No
N/A
All
Allow traffic from all source IP addresses in the container subnet CIDR block.
No
N/A
Outbound rule
All
No
N/A
ENI security group
In a CCE Turbo cluster, an additional security group named {Cluster name}-cce-eni-{Random ID} is created. By default, containers in the cluster are bound to this security group. For details about the default ports, see Table 7.
Table 7 Default ports of the ENI security group
Direction
Port
Modifiable
Inbound rules
All
ENI security group
Allow containers in a cluster to access each other.
No
N/A
VPC CIDR block
Allow instances in the cluster VPC to access containers.
No
N/A
Outbound rule
All
No
N/A
By default, all security groups created by CCE allow all the outbound traffic. You are advised to retain this configuration. To harden outbound rules, ensure that the ports listed in the following table are enabled.
Table 8 Minimum configurations of outbound security group rules for worker nodes
Port
Allowed CIDR
UDP port 53
DNS server of the subnet
Allow traffic on the port for domain name resolution.
UDP port 4789 (required only for clusters that use the tunnel networks)
All IP addresses
TCP port 5443
TCP port 5444
CIDR blocks of the VPC and container
TCP port 6443
None
TCP port 8445
VPC CIDR block
TCP port 9443
VPC CIDR block
All ports
198.19.128.0/17
Allow worker nodes to access the VPC Endpoint (VPCEP) service.
UDP port123
100.126.0.0/16
Allow worker nodes to access the internal NTP server.
TCP port 443
100.126.0.0/16
Allow worker nodes to access OBS over internal networks to pull the installation package.
TCP port 6443
100.126.0.0/16
Allow worker nodes to report that the worker nodes are installed.
