Help Center/
      Cloud Container Engine/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        Workload/
        Container Configuration/
      What Should I Do If Health Check Probes Occasionally Fail?
        Updated on 2022-11-10 GMT+08:00
When the liveness and readiness probes fail to perform the health check, locate the service fault first.
Common causes are as follows:
- The service processing takes a long time. As a result, the response times out.
- The Tomcat connection setup and waiting time are too long (for example, too many connections or threads). As a result, the response times out.
- The performance of the node where the container is located, such as the disk I/O, reaches the bottleneck. As a result, the service processing times out.
   Parent topic: Container Configuration
