Configuring the /etc/hosts File of a Pod Using hostAliases
Application Scenarios
If DNS or other related settings are inappropriate, you can use hostAliases to overwrite the resolution of the hostname at the pod level when adding entries to the /etc/hosts file of the pod.
- Use kubectl to connect to the cluster.
- Create the hostaliases-pod.yaml file.
    vi hostaliases-pod.yaml The field in bold in the YAML file indicates the image name and tag. You can replace the example value as required. apiVersion: v1 kind: Pod metadata: name: hostaliases-pod spec: hostAliases: - ip: 127.0.0.1 hostnames: - foo.local - bar.local - ip: 10.1.2.3 hostnames: - foo.remote - bar.remote containers: - name: cat-hosts image: tomcat:9-jre11-slim lifecycle: postStart: exec: command: - cat - /etc/hosts imagePullSecrets: - name: default-secretTable 1 pod field description Parameter Mandatory Description apiVersion Yes API version number kind Yes Type of the object to be created metadata Yes Metadata definition of a resource object name Yes Name of a pod spec Yes Detailed description of the pod. For details, see Table 2. Table 2 spec field description Parameter Mandatory Description hostAliases Yes Host alias containers Yes For details, see Table 3.
- Create a pod.
    kubectl create -f hostaliases-pod.yaml If information similar to the following is displayed, the pod is created. pod/hostaliases-pod created
- Query the pod status.
    kubectl get pod hostaliases-pod If the pod is in the Running state, the pod is successfully created. NAME READY STATUS RESTARTS AGE hostaliases-pod 1/1 Running 0 16m
- Check whether the hostAliases functions properly.
    docker ps |grep hostaliases-pod docker exec -ti Container ID /bin/sh
