Recommended GPU Driver Versions for CCE
This section describes the recommended driver versions for CCE clusters. If you use a non-recommended GPU driver version, make sure to check its compatibility with the model and OS. Select a proper NVIDIA driver version by checking the compatibility list for CUDA Toolkit and NVIDIA drivers based on the version used by your application.
Supported GPU Drivers
  • The list of supported GPU drivers applies only to CCE AI Suite (NVIDIA GPU) of v1.2.28 or later.
  • To use the latest GPU driver, upgrade your CCE AI Suite (NVIDIA GPU) to the latest version.
Table 1 Supported GPU drivers
GPU Model
Supported Cluster Type
Specification
OS
HCE OS 2.0
Ubuntu 22.04.5
Ubuntu 22.04.4
Ubuntu 22.04.3
CentOS Linux release 7.6
Tesla T4
CCE standard cluster
g6
pi2
535.216.03
535.54.03
510.47.03
470.57.02
535.216.03
535.161.08
535.216.03
535.161.08
535.216.03
535.161.08
535.54.03
470.141.03
535.54.03
470.141.03
Tesla V100
p2s
p2vs
p2v
535.216.03
535.54.03
510.47.03
470.57.02
535.216.03
535.161.08
535.216.03
535.161.08
535.216.03
535.161.08
535.54.03
470.141.03
535.54.03
470.141.03
