Configuring SNI for a LoadBalancer Ingress
An SNI certificate is an extended server certificate that allows the same IP address and port number to provide multiple access domain names for external systems. Different security certificates can be used based on the domain names requested by clients to ensure HTTPS communication security.
When configuring SNI, you need to add a certificate associated with a domain name. The client submits the requested domain name information when initiating an SSL handshake request. After receiving the SSL request, the load balancer searches for the certificate based on the domain name. If the certificate is found, the load balancer will return it to the client. If the certificate is not found, the load balancer will return the default server certificate.
You are allowed to use either of the following ways to configure an ingress certificate in a cluster:
  • Configuring SNI using a TLS certificate: You need to first import a certificate to a Secret. CCE will then automatically handle the certificate configurations on the ELB console and give a name to the certificate (started with k8s_plb_default). This certificate, which is generated by CCE, cannot be modified or deleted from the ELB console.
  • Configuring SNI using an ELB certificate: You are allowed to directly use certificates created on the ELB console. There is no need to manually configure the cluster Secrets, and you can modify the certificates on the ELB console.
Using the CCE Console to Configure an SNI Certificate
  • The SNI option is available only when HTTPS is used.
  • Only one domain name can be specified for each SNI certificate. Wildcard-domain certificates are supported.
  • Security policy (kubernetes.io/elb.tls-ciphers-policy) is supported only in clusters of v1.17.11 or later.
  2. Choose Services & Ingresses in the navigation pane, click the Ingresses tab, and click Create Ingress in the upper right corner.
  3. Configure ingress parameters.
    This example explains only key parameters for configuring SNI certificates. You can configure other parameters as required. For details, see Creating a LoadBalancer Ingress on the Console.
    Table 1 Key parameters
    Example
    Name
    Enter an ingress name.
    ingress-test
    Load Balancer
    Select a load balancer to be associated with the ingress or automatically create a load balancer.
    Shared
    Listener
    • External Protocol: Select HTTPS when configuring a certificate for an ingress.
    • External Port: specifies the port of the load balancer listener. The default HTTPS port is 443.
    • Certificate Source: Select TLS secret.
    • Server Certificate: kubernetes.io/tls and IngressTLS are supported.
      If no certificate is available, you can create a TLS certificate. For details about the configuration parameters, see Creating a Secret.
    • SNI: Enter a domain name and select a certificate. The SNI certificate must contain the domain name information. SNI certificates support two TLS secret types: kubernetes.io/tls and IngressTLS.
    • External Protocol: HTTPS
    • External Port: 443
    • Certificate Source: TLS secret
    • Server Certificate: test
    • SNI:
      • Domain Name: example.com
      • Certificate: example-test
    Forwarding Policy
    • Domain Name: Enter an actual domain name to be accessed. If it is left blank, the ingress can be accessed through the IP address. Ensure that the domain name has been registered and licensed. Once a forwarding policy is configured with a domain name specified, you must use the domain name for access.
    • Path Matching Rule: Select Prefix match, Exact match, or RegEx match.
    • Path: Enter the path provided by a backend application for external access. The path added must be valid in the backend application, or the forwarding cannot take effect.
    • Destination Service: Select an existing Service. Only Services that meet the requirements are automatically displayed in the Service list.
    • Destination Service Port: Select the access port of the destination Service.
    • Path Matching Rule: Prefix match
    • Path: /
    • Destination Service: nginx
    • Destination Service Port: 80
  4. Click OK.
Using kubectl to Configure an SNI Certificate
In this example, the sni-test-secret SNI certificate is used as an example. The specified domain name must be the same as that of the SNI certificate.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    An example YAML file of an ingress associated with an automatically created load balancer is as follows:
    For clusters of v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      annotations:
        kubernetes.io/elb.class: performance
        kubernetes.io/ingress.class: cce
        kubernetes.io/elb.port: '443'
        kubernetes.io/elb.autocreate:
              "type": "public",
              "bandwidth_name": "cce-bandwidth-******",
              "bandwidth_chargemode": "bandwidth",
              "bandwidth_size": 5,
              "bandwidth_sharetype": "PER",
              "eip_type": "5_bgp",
              "available_zone": [
                  "ae-ad-1a"
              "elb_virsubnet_ids":["b4bf8152-6c36-4c3b-9f74-2229f8e640c9"],
              "l7_flavor_name": "L7_flavor.elb.s1.small"
        kubernetes.io/elb.tls-ciphers-policy: tls-1-2
      tls:
      - secretName: ingress-test-secret # A server certificate must be specified.
      - hosts:
          - example.com  # Domain name specified when an SNI certificate is issued
        secretName: sni-test-secret   #SNI certificate
      rules:
      - host: example.com   #The domain name must be the same as the value of hosts in the tls field.
        http:
          paths:
          - path: '/'
            backend:
              serviceName: <your_service_name>  # Replace it with the name of your target Service.
              servicePort: 80
            property:
    For clusters of v1.23 or later:
    kind: Ingress
      annotations:
              "type": "public",
              "available_zone": [
                  "ae-ad-1a"
      tls:
      - hosts:
        secretName: sni-test-secret # SNI certificate
      rules:
      - host: example.com   # The domain name must be the same as the value of hosts in the tls field.
        http:
          paths:
          - path: '/'
            backend:
              service:
                name: <your_service_name>  # Replace it with the name of your target Service.
                port:
                  number: 80             # Replace 80 with the port number of your target Service.
            property:
      ingressClassName: cce
  3. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  4. Check the created ingress.
    kubectl get ingress
    NAME           CLASS  HOSTS          ADDRESS          PORTS   AGE
    ingress-test   cce    example.com    121.**.**.**     80,443  10s
  5. Use HTTPS to access the ingress. ${ELB_IP} specifies the IP address accessed by the target ingress.
    curl -H "Host:example.com" -k https://${ELB_IP}:443
    If the ingress can be accessed, the certificate is configured.
Using the CCE Console to Configure an SNI Certificate Created on the ELB Console
  • If both an ELB certificate and a TLS certificate are specified for the same ingress, the ingress will use the ELB certificate.
  • CCE does not check whether an ELB certificate is valid. It only checks whether the certificate is present.
  • Only ingresses in clusters of v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later support ELB certificates.
    Table 2 Key parameters
    Example
    Name
    ingress-test
    Load Balancer
    Shared
    Listener
    • External Protocol: Select HTTPS.
    • Certificate Source: Select ELB server certificate.
    • Server Certificate: Use a certificate created on ELB.
      If no certificate is available, go to the ELB console and create one.
    • SNI: Select the corresponding SNI certificate, which must contain the domain name information.
    • Certificate Source: ELB server certificate
    • Server Certificate: cert-test
    • SNI: cert-example
    Forwarding Policy
    • Domain Name: You do not need to configure this parameter.
    • Path: /
  4. Click OK.
Using kubectl to Configure an SNI Certificate Created on the ELB Console
To use an ELB certificate for an ingress, you can specify the kubernetes.io/elb.tls-certificate-ids annotation.
    An example YAML file of an ingress associated with an existing load balancer is as follows:
    kind: Ingress
      annotations:
        kubernetes.io/elb.id: 0b9a6c4d-bd8b-45cc-bfc8-ff0f9da54e95
        kubernetes.io/elb.class: union
        kubernetes.io/elb.tls-certificate-ids: 058cc023690d48a3867ad69dbe9cd6e5,b98382b1f01c473286653afd1ed9ab63
      rules:
      - host: ''
        http:
          paths:
          - path: '/'
            backend:
              servicePort: 80
            property:
    kind: Ingress
      namespace: default
      annotations:
      rules:
        - host: ''
          http:
            paths:
              - path: '/'
                backend:
                  service:
                    port:
                property:
    Table 3 Key parameters
    Type
    String
    ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained.
    If an SNI certificate cannot be found based on the domain name requested by the client, the server certificate will be returned by default.
    To obtain the certificate, log in to the CCE console, choose Service List > Networking > Elastic Load Balance, and click Certificates in the navigation pane. In the load balancer list, copy the ID under the target certificate name.
    kubectl get ingress
    ingress-test  cce      *         121.**.**.**     80,443  10s
