Adding a Container CIDR Block for a Cluster
If the container CIDR block configured during CCE cluster creation cannot meet service expansion requirements, you can add a container CIDR block for the cluster.
Notes and Constraints
  • This function is available only for clusters of v1.19 or later using a VPC network.
  • An added container CIDR block cannot be deleted.
Adding a Container CIDR Block for a CCE Standard Cluster
  2. On the Overview page, locate the Networking Configuration area and click Add.
  3. Configure the container CIDR block to be added. You can click to add multiple container CIDR blocks at a time.
    New container CIDR blocks cannot conflict with service CIDR blocks, VPC CIDR blocks, and existing container CIDR blocks.
  4. Click OK.
