Modifying Node Pool Configurations
Notes and Constraints
The default node pool does not support the management operations described in this section.
Configuration Management
CCE allows you to highly customize Kubernetes parameter settings on core components in a cluster. For more information, see kubelet.
This function is supported only in clusters of v1.15 or later. It is not displayed for versions earlier than v1.15.
- Log in to the CCE console.
- Click the cluster name to access the cluster console. Choose Nodes in the navigation pane. In the right pane, click the Node Pools tab.
- Click Manage in the Operation column of the target node pool
- On the Manage Configurations page on the right, modify node pool parameter setting.
The following parameters can be configured for a node pool:
- Click OK.
kubelet
Item |
Parameter |
Description |
Value |
Modification |
CPU management policy |
cpu-manager-policy |
CPU management policy configuration. For details, see CPU Scheduling.
Default: none |
The CPU management policy does not apply to ECS (PM) node pools in CCE Turbo clusters. |
QPS for requests to kube-apiserver |
kube-api-qps |
Number of queries per second for communication with the API server. |
Default: 100 |
None |
Burst for requests to kube-apiserver |
kube-api-burst |
Maximum number of burst requests sent to the API server per second. |
Default: 100 |
None |
Limit on the pods managed by kubelet |
max-pods |
Maximum number of pods that can run on a node. |
None |
Limited number of processes in a pod |
pod-pids-limit |
Maximum number of PIDs that can be used in each pod. |
Default: -1, which indicates that the number of PIDs is not limited |
None |
Whether to use a local IP address as a node's ClusterDNS |
with-local-dns |
The default ENI IP address of the node will be automatically added to the node's kubelet configuration as the preferred DNS address. |
Default: false |
None |
QPS limit on creating events |
event-qps |
Number of events that can be generated per second. |
Default: 5 |
None |
Upper Limit for Burst Events |
event-burst |
Upper limit for burst event creation. The number of burst events can be temporarily increased to the specified value. |
Default: 10 |
None |
Allowed unsafe sysctls |
allowed-unsafe-sysctls |
Insecure system configuration allowed. Starting from v1.17.17, CCE enables pod security policies for kube-apiserver. Add corresponding configurations to allowedUnsafeSysctls of a pod security policy to make the policy take effect. (This configuration is not required for clusters earlier than v1.17.17.) For details, see Example of Enabling Unsafe sysctls in a PSP. |
Default: [] |
None |
Topology management policy |
topology-manager-policy |
Set the topology management policy. Valid values are as follows:
Default: none |
NOTICE:
Modifying topology-manager-policy and topology-manager-scope will restart kubelet, and the resource allocation of pods will be recalculated based on the modified policy. In this case, running pods may restart or even fail to receive any resources. |
Topology management scope |
topology-manager-scope |
Configure the resource alignment granularity of the topology management policy. Valid values are as follows:
Default: container |
Specified DNS configuration file |
resolv-conf |
DNS resolution configuration file specified by the container |
Default: null |
None |
Timeout for all runtime requests except long-running requests |
runtime-request-timeout |
Timeout interval of all runtime requests except long-running requests (pull, logs, exec, and attach). |
Default: 2m0s |
This parameter is available only in clusters of v1.21.10-r0, v1.23.8-r0, v1.25.3-r0, or later versions. |
Whether to allow kubelet to pull only one image at a time |
serialize-image-pulls |
Pull an image in serial mode.
Image repository pull limit per second |
registry-pull-qps |
QPS upper limit of an image repository. |
Default: 5 Value range: 1 to 50 |
Upper limit of burst image pull |
registry-burst |
Maximum number of burst image pulls. |
Default: 10 The value ranges from 1 to 100 and must be greater than or equal to the value of registry-pull-qps. |
Maximum Number of Container Log Files |
container-log-max-files |
Maximum number of container log files. When the number of existing log files exceeds this value, the earliest log file will be deleted to release space for new log files. |
Default: 10 Value range: 2 to 100 |
This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions. |
Maximum Container Log File Size |
container-log-max-size |
Maximum size of a single container log file. When the size of a log file reaches this value, the current log file will be closed and a new log file will be created to continue logging. |
Default: 50 Value range: 1 to 4096 |
Upper Limit for Image Garbage Collection |
image-gc-high-threshold |
When the kubelet disk usage reaches this value, kubelet starts to collect image garbage. |
Default: 80 Value range: 1 to 100 |
To disable image garbage collection, set this parameter to 100. This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions. |
Lower Limit for Image Garbage Collection |
image-gc-low-threshold |
Image garbage collection stops when the disk usage drops below the specified threshold. |
Default: 70 Value range: 1 to 100 |
The value of this parameter cannot be greater than the upper limit for image garbage collection. This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions. |
Node memory reservation |
system-reserved-mem |
System memory reservation reserves memory resources for OS system daemons such as sshd and udev. |
Default value: automatically calculated, which varies depending on node flavors. For details, see Node Resource Reservation Policy.
Optional configurations are as follows:
The sum of kube-reserved-mem and system-reserved-mem must be less than 50% of the minimum memory of nodes in the node pool. |
kube-reserved-mem |
Kubernetes memory reservation reserves memory resources for Kubernetes daemons such kubelet and container runtime. |
Hard eviction |
memory.available |
Available memory on a node. |
The value is fixed at 100 MiB. |
For details, see Node-pressure Eviction.
NOTICE:
Exercise caution when modifying an eviction configuration item. Improper configuration may cause pods to be frequently evicted or fail to be evicted when the node is overloaded. kubelet can identify the following specific file system identifiers:
nodefs.available |
Percentage of the available capacity in the filesystem used by kubelet. |
Default: 10% Value range: 1% to 99% |
nodefs.inodesFree |
Percentage of available inodes in the filesystem used by kubelet. |
Default: 5% Value range: 1% to 99% |
imagefs.available |
Percentage of the available capacity in the filesystem used by container runtimes to store resources such as images. |
imagefs.inodesFree |
Percentage of available inodes in the filesystem used by container runtimes to store resources such as images. |
This parameter is left blank by default. Value range: 1% to 99% |
pid.available |
Percentage of allocatable PIDs reserved for pods. |
Soft eviction |
memory.available |
Available memory on a node. The value must be greater than the hard eviction value of the same parameter, and the eviction grace period (evictionSoftGracePeriod) must be configured accordingly. |
This parameter is left blank by default. Value range: 100 to 1000000 |
nodefs.available |
Percentage of the available capacity in the filesystem used by kubelet. The value must be greater than the hard eviction value of the same parameter, and the eviction grace period (evictionSoftGracePeriod) must be configured accordingly. |
nodefs.inodesFree |
Percentage of available inodes in the filesystem used by kubelet. The value must be greater than the hard eviction value of the same parameter, and the eviction grace period (evictionSoftGracePeriod) must be configured accordingly. |
imagefs.available |
Percentage of the available capacity in the filesystem used by container runtimes to store resources such as images. The value must be greater than the hard eviction value of the same parameter, and the eviction grace period (evictionSoftGracePeriod) must be configured accordingly. |
Percentage of available inodes in the filesystem used by container runtimes to store resources such as images. The value must be greater than the hard eviction value of the same parameter, and the eviction grace period (evictionSoftGracePeriod) must be configured accordingly. |
pid.available |
Percentage of allocatable PIDs reserved for pods. The value must be greater than the hard eviction value of the same parameter, and the eviction grace period (evictionSoftGracePeriod) must be configured accordingly. |
kube-proxy
Item |
Parameter |
Description |
Value |
Modification |
Maximum number of connection tracking entries |
conntrack-min |
Maximum number of connection tracking entries To obtain the value, run the following command: sysctl net.nf_conntrack_max |
Default: 131072 |
None |
Wait time of a closed TCP connection |
conntrack-tcp-timeout-close-wait |
Wait time of a closed TCP connection To obtain the value, run the following command: sysctl net.netfilter.nf_conntrack_tcp_timeout_close_wait |
Default: 1h0m0s |
None |
Docker (Available Only for Docker Node Pools)
Item |
Parameter |
Description |
Value |
Modification |
Container umask |
native-umask |
The default value normal indicates that the umask value of the started container is 0022. |
Default: normal |
The parameter value cannot be changed. |
Available data space for a single container |
docker-base-size |
Maximum data space that can be used by each container. |
Default: 0 |
Insecure image source address |
insecure-registry |
Whether an insecure image source address can be used. |
false |
Maximum size of a container core file |
limitcore |
Maximum size of a core file in a container. The unit is byte. If not specified, the value is infinity. |
Default: 5368709120 |
None |
Limit on the number of handles in a container |
default-ulimit-nofile |
Maximum number of handles that can be used in a container. |
Default: {soft}:{hard} |
The value cannot exceed the value of the kernel parameter nr_open and cannot be a negative number. You can run the following command to obtain the kernel parameter nr_open: sysctl -a | grep nr_open |
Image pull timeout |
image-pull-progress-timeout |
If the image fails to be pulled before time outs, the image pull will be canceled. |
Default: 1m0s |
This parameter is supported in v1.25.3-r0 and later. |
Maximum Number of Concurrent Requests for Downloading an Image at a Time |
max-concurrent-downloads |
This parameter specifies the maximum number of concurrent requests for downloading an image at a time. |
Default: 3 Value range: 1 to 20 |
If this parameter is set to a large value, the network performance of other services on the node may be affected or the disk I/O and CPU usage may increase. This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions. |
max-size |
Maximum size of a container log file to be dumped. When the size of a log file reaches this value, the current log file will be closed and a new log file will be created to continue logging. |
If this parameter is set to a small value, important logs may be lost. If this parameter is set to a large value, too much disk space may be occupied. This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions. |
max-file |
Maximum number of log files that can be retained in a container. When the number of existing log files exceeds this value, the earliest log file will be deleted to release space for new log files. |
Default: 20 Value range: 2 to 100 |
Modify Image Repository Configuration |
registry-mirrors |
You can configure one or multiple substitute image repositories to be selected when obtaining images from the container runtime. |
Default: [] Enter an IP address or domain name starting with http:// or https:// for a substitute image repository. For example, if you use the on-premises image repositories with IP addresses http://example.com and https://example.com, respectively, as the substitute repositories of the default repository, the parameter value is ["http://example.com,https://example.com"]. |
NOTICE:
If a substitute image repository is configured incorrectly, containers may not be able to pull the necessary image. This parameter is available only in clusters of v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later versions. |
containerd (Available Only for containerd Node Pools)
Item |
Parameter |
Description |
Value |
Modification |
limitcore |
None |
Default: 1048576 |
Default: 1m0s |
Verification on insure skips |
insecure_skip_verify |
Whether to skip repository certificate verification. |
Default: false |
Maximum Container Log Line Size |
max-container-log-line-size |
Maximum log line size of a container, in the unit of bytes. The log lines exceeding the limit will be split into multiple lines. |
Default: 16384 Value range: 1 to 2097152 |
A larger value will lead to more containerd memory consumption. This parameter is available only in clusters of v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later versions. |
container-base-size |
Default: 0 |
registry-mirrors |
If you do not specify this parameter, the docker.io image repository will be used by default, and the SWR image repository will be used as a substitute. An image repository must be an IP address or domain name. A substitute image repository must be an IP address or domain name starting with http:// or https://. |
This parameter is available only in clusters of v1.23.17-r0, v1.25.12-r0, v1.27.9-r0, v1.28.7-r0, v1.29.3-r0, or later versions.
NOTICE:
If the image repository or its substitute is configured incorrectly, containers may not be able to pull the necessary image. |
Certificate Authentication Skipped Image Repository |
insecure-registries |
When you specify image repositories, you can bypass security certificate-based authentication. This is typically done to connect to an insecure or self-signed image repository. |
This parameter is left blank by default. Enter an IP address or domain name. |
This parameter is available only in clusters of v1.23.17-r0, v1.25.12-r0, v1.27.9-r0, v1.28.7-r0, v1.29.3-r0, or later versions. |
Networking Components (Available Only for CCE Turbo Clusters)
Item |
Parameter |
Description |
Value |
Modification |
Node pool ENI pre-binding |
enable-node-nic-configuration |
Whether to enable ENI pre-binding in a node pool. |
Default: false |
After network component configuration is disabled in a node pool, the dynamic container ENI pre-binding parameter settings of the node pool are the same as those of cluster-level parameter settings. |
Minimum number of ENIs bound to a node in a node pool |
nic-minimum-target |
Minimum number of container ENIs bound to a node. The parameter value must be a positive integer. The value 10 indicates that at least 10 container ENIs must be bound to a node. If the number you specified exceeds the container ENI quota of the node, the ENI quota will be used. |
Default: 10 |
Configure these parameters based on the number of pods typically running on most nodes. |
Maximum number of ENIs pre-bound to a node in a node pool |
nic-maximum-target |
After the number of ENIs bound to a node exceeds the nic-maximum-target value, CCE will not proactively pre-bind ENIs. Checking the upper limit of pre-bound container ENIs is enabled only when the value of this parameter is greater than or equal to the minimum number of container ENIs (nic-minimum-target) bound to a node. The parameter value must be a positive integer. The value 0 indicates that checking the upper limit of pre-bound container ENIs is disabled. If the number you specified exceeds the container ENI quota of the node, the ENI quota will be used. |
Default: 0 |
Configure these parameters based on the maximum number of pods running on most nodes. |
Number of ENIs dynamically pre-bound to a node in a node pool |
nic-warm-target |
Extra ENIs will be pre-bound after the nic-minimum-target is used up in a pod. The value can only be a number. When the sum of the nic-warm-target value and the number of ENIs bound to the node is greater than the nic-maximum-target value, CCE will pre-bind the number of ENIs specified by the difference between the nic-maximum-target value and the current number of ENIs bound to the node. |
Default: 2 |
Set the parameter value to the number of pods that can be scaled out instantaneously within 10 seconds on most nodes. |
Threshold for reclaiming the ENIs pre-bound to a node in a node pool |
nic-max-above-warm-target |
Only when the difference between the number of idle ENIs on a node and the nic-warm-target value is greater than the threshold, the pre-bound ENIs will be unbound and reclaimed. The value can only be a number.
Default: 2 |
Set the parameter value to the difference between the number of pods that are frequently scaled on most nodes within minutes and the number of pods that are instantly scaled out on most nodes within 10 seconds. |
Pod Security Groups (Available Only for CCE Turbo Clusters)
Item |
Parameter |
Description |
Value |
Modification |
Default security group used by pods in a node pool |
security_groups_for_nodepool |
You can enter the security group ID. If this parameter is not configured, the default security group of the cluster container network will be used, and a maximum of five security group IDs that are separated by semicolons (;) can be specified at a time. The priority of the security group is lower than that of the security group configured for SecurityGroups. |
None |
None |
