Help Center/
Cloud Container Engine/
User Guide (ME-Abu Dhabi Region)/
Clusters/
Upgrading a Cluster/
Troubleshooting for Pre-upgrade Check Exceptions/
ELB Listener Access Control
Check Items
Check whether ELB listener access control has been configured using annotations for the Services in the current cluster.
If so, check whether their configurations are correct.
Solution
If the configurations are incorrect, contact O&M personnel.
Parent topic: Troubleshooting for Pre-upgrade Check Exceptions
