هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ Network/ Service/ LoadBalancer/ Configuring Passthrough Networking for a LoadBalancer Service
Background
A Kubernetes cluster can publish applications running on a group of pods as Services, which provide unified layer-4 access entries. For a Loadbalancer Service, kube-proxy configures the LoadbalanceIP in status of the Service to the local forwarding rule of the node by default. When a pod accesses the load balancer from within the cluster, the traffic is forwarded within the cluster instead of being forwarded by the load balancer.
kube-proxy is responsible for intra-cluster forwarding. kube-proxy has two forwarding modes: iptables and IPVS. iptables is a simple polling forwarding mode. IPVS has multiple forwarding modes but it requires modifying the startup parameters of kube-proxy. Compared with iptables and IPVS, load balancers provide more flexible forwarding policies as well as health check capabilities.
Solution
CCE supports passthrough networking. You can configure the annotation of kubernetes.io/elb.pass-through for the Loadbalancer Service. Intra-cluster access to the Service load balancer address is then forwarded to backend pods by the load balancer.
Figure 1 Passthrough networking illustration
  • CCE clusters
    When a LoadBalancer Service is accessed within the cluster, the access is forwarded to the backend pods using iptables/IPVS by default.
    When a LoadBalancer Service (configured with elb.pass-through) is accessed within the cluster, the access is first forwarded to the load balancer, then the nodes, and finally to the backend pods using iptables/IPVS.
  • CCE Turbo clusters
    When a client accesses a LoadBalancer Service from within the cluster, passthrough is used by default. In this case, the client directly accesses the load balancer private network IP address and then access a container through the load balancer.
  • In a CCE standard cluster, after passthrough networking is configured for a dedicated load balancer, the private IP address of the load balancer cannot be accessed from the node where the workload pod resides or other containers on the same node as the workload.
  • Passthrough networking is not supported for clusters of v1.15 or earlier.
  • In IPVS network mode, the passthrough settings of Services connected to the same load balancer must be the same.
  • If node-level (local) service affinity is used, kubernetes.io/elb.pass-through is automatically set to onlyLocal to enable pass-through.
This section describes how to create a Deployment using an Nginx image and create a Service with passthrough networking enabled.
  1. Use the Nginx image to create a Deployment.
    apiVersion: apps/v1
    kind: Deployment
      replicas: 2
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          containers:
          - image: nginx:latest
            resources:
              limits:
                cpu: 100m
                memory: 200Mi
              requests:
                cpu: 100m
                memory: 200Mi
          imagePullSecrets:
          - name: default-secret
  2. For a LoadBalance Service, set kubernetes.io/elb.pass-through to true. In this example, a shared load balancer named james is automatically created.
    apiVersion: v1
    kind: Service
      annotations:
        kubernetes.io/elb.pass-through: "true"
        kubernetes.io/elb.class: union
        kubernetes.io/elb.autocreate: '{"type":"public","bandwidth_name":"cce-bandwidth","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james"}'
      labels:
        app: nginx
      externalTrafficPolicy: Local
      ports:
      - name: service0
        port: 80
        protocol: TCP
        targetPort: 80
      selector:
        app: nginx
      type: LoadBalancer
Verification
Check the load balancer associated with the created Service. The load balancer name is james. The number of load balancer connections is 0.
Use kubectl to connect to the cluster, go to an Nginx container, and access the ELB address. The access is successful.
# kubectl get pod
NAME                     READY   STATUS    RESTARTS   AGE
nginx-7c4c5cc6b5-vpncx   1/1     Running   0          9m47s
nginx-7c4c5cc6b5-xj5wl   1/1     Running   0          9m47s
# kubectl exec -it nginx-7c4c5cc6b5-vpncx -- /bin/sh
# curl 120.46.141.192
<!DOCTYPE html>
<html>
<head>
<title>Welcome to nginx!</title>
<style>
    body {
        width: 35em;
        margin: 0 auto;
        font-family: Tahoma, Verdana, Arial, sans-serif;
</style>
</head>
<body>
<h1>Welcome to nginx!</h1>
<p>If you see this page, the nginx web server is successfully installed and
working. Further configuration is required.</p>
<p>For online documentation and support please refer to
<a href="http://nginx.org/">nginx.org</a>.<br/>
Commercial support is available at
<a href="http://nginx.com/">nginx.com</a>.</p>
<p><em>Thank you for using nginx.</em></p>
</body>
</html>
Wait for a period of time and view the ELB monitoring data. A new access connection is created for the ELB, indicating that the access passes through the ELB load balancer as expected.
