هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
Default GPU Scheduling in Kubernetes
You can use GPUs in CCE containers.
  • A GPU node has been created. For details, see Creating a Node.
  • The CCE AI Suite (NVIDIA GPU) add-on has been installed. During the installation, select the driver corresponding to the GPU model on the node. For details, see CCE AI Suite (NVIDIA GPU).
  • When the default GPU scheduling is used in clusters of v1.27 or earlier, the CCE AI Suite (NVIDIA GPU) add-on mounts the driver directory to /usr/local/nvidia/lib64, so you need to add /usr/local/nvidia/lib64 to the LD_LIBRARY_PATH environment variable to use GPUs in a container. You can skip this step for clusters of v1.28 or later.
    You can add environment variables in any of the following ways:
    • Configure the LD_LIBRARY_PATH environment variable in the Dockerfile used for creating an image. (Recommended)
      ENV LD_LIBRARY_PATH /usr/local/nvidia/lib64:$LD_LIBRARY_PATH
    • Configure the LD_LIBRARY_PATH environment variable in the image startup command.
      /bin/bash -c "export LD_LIBRARY_PATH=/usr/local/nvidia/lib64:$LD_LIBRARY_PATH && ..."
    • Define the LD_LIBRARY_PATH environment variable when creating a workload. (Ensure that this variable is not configured in the container. Otherwise, it will be overwritten.)
                env:
                  - name: LD_LIBRARY_PATH
                    value: /usr/local/nvidia/lib64
Using GPUs
Create a workload and request GPUs. You can specify the number of GPUs as follows:
apiVersion: apps/v1
kind: Deployment
  namespace: default
  replicas: 1
  selector:
    matchLabels:
      app: gpu-test
  template:
      labels:
        app: gpu-test
      containers:
      - image: nginx:perl
        resources:
          requests:
            cpu: 250m
            memory: 512Mi
            nvidia.com/gpu: 1   # Number of requested GPUs
          limits:
            cpu: 250m
            memory: 512Mi
            nvidia.com/gpu: 1   # Maximum number of GPUs that can be used
      imagePullSecrets:
      - name: default-secret
nvidia.com/gpu specifies the number of GPUs to be requested. The value can be smaller than 1. For example, nvidia.com/gpu: 0.5 indicates that multiple pods share a GPU. In this case, all the requested GPU resources come from the same GPU card.
When you use nvidia.com/gpu to specify the number of GPUs, the values of requests and limits must be the same.
After nvidia.com/gpu is specified, workloads will not be scheduled to nodes without GPUs. If the node is GPU-starved, Kubernetes events similar to the following are reported:
  • 0/2 nodes are available: 2 Insufficient nvidia.com/gpu.
  • 0/4 nodes are available: 1 InsufficientResourceOnSingleGPU, 3 Insufficient nvidia.com/gpu.
To use GPU resources on the CCE console, you only need to configure the GPU quota when creating a workload.
GPU Node Labels
CCE will label GPU-enabled nodes after they are created. Different types of GPU-enabled nodes have different labels.
$ kubectl get node -L accelerator
NAME           STATUS   ROLES    AGE     VERSION                                    ACCELERATOR
10.100.2.179   Ready    <none>   8m43s   v1.19.10-r0-CCE21.11.1.B006-21.11.1.B006   nvidia-t4
When using GPUs, you can enable the affinity between pods and nodes based on labels so that the pods can be scheduled to the correct nodes.
apiVersion: apps/v1
kind: Deployment
  namespace: default
  replicas: 1
  selector:
    matchLabels:
      app: gpu-test
  template:
      labels:
        app: gpu-test
      nodeSelector:
        accelerator: nvidia-t4
      containers:
      - image: nginx:perl
        resources:
          requests:
            cpu: 250m
            memory: 512Mi
          limits:
            cpu: 250m
            memory: 512Mi
      imagePullSecrets:
