Migrating Services Across Clusters of Different Versions
Application Scenarios
This section describes how to migrate services from a cluster of an earlier version to a cluster of a later version in CCE.
This operation is applicable when a cross-version cluster upgrade is required (for example, upgrade from v1.19.* to v1.28.*) and new clusters can be created for service migration.
Category |
Description |
Cluster |
NodeIP-related: Check whether node IP addresses (including EIPs) of the cluster before the migration have been used in other configurations or trustlists. |
Workloads |
Record the number of workloads for post-migration check. |
Storage |
Network |
O&M |
Private configuration: Check whether kernel parameters or system data have been configured on nodes in the cluster. |
- Create a CCE cluster.
Create a cluster with the same specifications and configurations as the cluster of the earlier version. For details, see Buying a CCE Standard/Turbo Cluster.
- Add a node.
Add a node with the same specifications and manual configuration items. For details, see Creating a Node.
- Create a storage volume in the new cluster.
Use the existing storage to create a PVC in the new cluster. The PVC name remains unchanged. For details, see Using an Existing OBS Bucket Through a Static PV or Using an Existing SFS Turbo File System Through a Static PV.
Storage switching supports only shared storage such as OBS and SFS Turbo. If non-shared storage is used, suspend the workloads in the old cluster to switch the storage resources. In this case, services will be unavailable.
- Create a workload in the new cluster.
Create a workload in the new cluster. The name and specifications remain unchanged. For details, see Creating a Deployment or Creating a StatefulSet.
- Mount the storage again.
Remount the existing storage in the workload. For details, see Using an Existing OBS Bucket Through a Static PV or Using an Existing SFS Turbo File System Through a Static PV.
- Create a Service in the new cluster.
The Service name and specifications remain unchanged. For details about how to create a Service, see Service.
- Commission services.
After all resources are created, commission the containerized services. If the commissioning is successful, migrate the services to the new cluster.
- Delete the old cluster.
When all functions of the new cluster are stable, delete the old cluster. For details about how to delete a cluster, see Deleting a Cluster.
