Managing Tags
Tags classify your gateways to facilitate search, analysis, and management.
You can search, analyze, and manage your resources on the Tag Management Service (TMS) console.
- Go to the APIG console.
 - In the navigation pane, choose Gateways.
 - Click Access Console or the name of the target gateway.
 - On the Tags tab, click Add Tag.
A tag consists of a key and value. The value can be empty.
 - Click OK.
Related Operations
Use the tags to filter, view, analyze, and manage your gateway resources on the TMS console.
- Hover over
 on the left to expand the service list, and enter TMS. - On the TMS console, enter the required information to filter gateway resources.
- Region: Select the region where the gateway is.
 - Resource Type: Select APIG.
 - Resource Tag: Select a tag key.
