هذه الصفحة غير متوفرة حاليًا بلغتك المحلية. نحن نعمل جاهدين على إضافة المزيد من اللغات. شاكرين تفهمك ودعمك المستمر لنا.
Creating a Gateway Response
A gateway response is displayed if APIG fails to process an API request. APIG provides a set of default responses and also allows you to create responses with custom status codes and content. The response content must be in JSON format.
For example, the content of a default gateway response is as follows:
{"error_code": "$context.error.code", "error_msg": "$context.error.message", "request_id": "$context.requestId"}
You can add a response with the following content:
{"errorcode": "$context.error.code", "errormsg": "$context.error.message", "requestid": "$context.requestId","apiId":"$context.apiId"}
You can add more fields to or delete existing fields from the JSON body.
  • You can create a maximum of four gateway responses for each group.
  • A maximum of 10 response headers can be customized. The key of a response header can contain 1 to 128 characters, including digits, letters, and underscores (_). The value can reference runtime variables (see Context Variables), but cannot contain double brackets ([[ or ]]).
  • The type of a default or custom response cannot be modified, but the status code and content of the response can.
  • The type of a gateway response cannot be changed. For details, see Response Types.
  • Gateway responses can contain the API gateway context variables (starting with $context). For details, see Context Variables.
  1. Go to the APIG console.
  1. Select a dedicated gateway at the top of the navigation pane.
  1. Choose API Management > API Groups.
  1. Click a group name.
  2. Click the Group Information tab.
  3. In the Gateway Responses area, create or modify gateway responses.
    To cancel modifications to a default response, click Restore Defaults in the upper right.
Response Types
The following table lists the response types supported by APIG. You can define status codes to meet your service requirements.
Table 1 Error response types supported by APIG
Response Name
Default Status Code
Access Denied
403
Access denied. For example, the access control policy is triggered or an attack is detected.
Authorizer Configuration Error
500
A custom authorizer error has occurred. For example, communication failed or an error response was returned.
Authorizer Failed
500
The custom authorization failed.
Incorrect Identity Source
401
The identity source of the custom authorizer is missing or invalid.
Third-Party Configuration Error
500
A third-party authorizer error has occurred. For example, communication failed or an error response was returned.
Third-Party Authorizer Failure
401
The third-party authorizer returns an authentication failure.
Incorrect Third-Party Identity Source
401
The identity source of the third-party authorizer is missing.
Authentication Failure
401
IAM or app authentication failed.
Identity Source Not Found
401
No identity source has been specified.
Backend Timeout
504
Communication with the backend service timed out.
Backend Unavailable
502
The backend service is unavailable due to communication error.
Default 4XX
Another 4XX error occurred.
Default 5XX
Another 5XX error occurred.
No API Found
404
No API is found.
Incorrect Request Parameters
400
The request parameters are incorrect or the HTTP method is not supported.
Request Throttled
429
The request was rejected due to request throttling.
Unauthorized Credential
401
The credential you are using has not been authorized to call the API.
Context Variables
Table 2 Variables that can be used in response message body
Variable
$context.apiId
API ID.
$context.apiName
API name.
$context.appId
ID of the credential that calls the API.
$context.appName
Name of the credential that calls the API.
$context.requestId
Request ID generated when the API is called.
$context.stage
Deployment environment in which the API is called.
$context.sourceIp
Source IP address of the API caller.
$context.reqPath
API request path, excluding the query string.
$context.reqUri
API request path, including the query string.
$context.reqMethod
Request method.
$context.authorizer.frontend.property
Values of the specified attribute–value pairs mapped to the context in the frontend custom authorizer response
$context.authorizer.backend.property
Values of the specified attribute–value pairs mapped to the context in the backend custom authorizer response
Error message.
$context.error.code
Error code.
$context.error.type
Error type.
