Help Center/
      API Gateway/
        User Guide (ME-Abu Dhabi Region)/
        FAQs/
        API Calling/
      Why Am I Seeing the Message "No backend available"?
- Check whether the backend service is accessible, and modify the backend service if it is inaccessible.
 - Check the ECS security group configurations of the backend service and verify that the required port has been enabled.
 - Check whether the backend service address is a public IP address. If yes, enable outbound access on the Gateways > Access Console > Gateway Information page.
 - Check whether ACL configurations of the VPC restrict the communication between the API gateway and the subnet where the backend service is located.
 - If you use a VPC channel, check whether the service port, health check port, and backend servers of the VPC channel have been correctly configured.
   Parent topic: API Calling
