# 自定义通知
**接口描述**
该接口用于自定义前台通知
**注意事项**
- 使用自定义通知将彻底替换默认通知，需要对应用进行充分测试，否则可能影响到前台服务的拉起。
**方法定义**
* 设置自定义通知
* @param customNotification 自定义通知对象
     * @param notificationId 通知id
void setCustomNotification(Notification customNotification, int notificationId);
**参数描述**
| 参数                 | 是否必须 | 类型           | 描述      |
| customNotification | 是    | Notification | 自定义通知对象 |
| notificationId     | 是    | int          | 自定义通知id |
**示例代码**
shareServiceController.setCustomNotification(createNotification(), GlobalConstant.NOTIFICATION_ID);
private Notification createNotification() {
        // Android8.0以上的系统，新建消息通道
        if (Build.VERSION.SDK_INT >= Build.VERSION_CODES.O) {
            // 用户可见的通道名称
            String channelName = getString(R.string.air_presence_app_name);
            // 通道的重要程度
            int importance = NotificationManager.IMPORTANCE_HIGH;
            NotificationChannel notificationChannel =
                    new NotificationChannel(GlobalConstant.CHANNEL_ID, channelName, importance);
            NotificationManager notificationManager = getSystemService(NotificationManager.class);
            if (notificationManager != null) {
                notificationManager.createNotificationChannel(notificationChannel);
        NotificationCompat.Builder builder = new NotificationCompat.Builder(this, GlobalConstant.CHANNEL_ID);
        // 通知小图标
        builder.setSmallIcon(R.drawable.ic_launcher);
        // 通知标题
        builder.setContentTitle(getString(R.string.ideashare_return_application));
        // 通知时间
        builder.setWhen(System.currentTimeMillis());
        // 设定启动的内容
        Intent activityIntent = new Intent(this, ProjectionActivity.class);
        PendingIntent pendingIntent =
                PendingIntent.getActivity(this,
                        GlobalConstant.JUMP_BACK_CODE, activityIntent, PendingIntent.FLAG_UPDATE_CURRENT);
        builder.setContentIntent(pendingIntent);
        // 通知按钮
        Intent stopShareIntent = new Intent(this, NotificationReceiver.class);
        stopShareIntent.setAction(NotificationReceiver.ACTION_STOP_PROJECTION);
        PendingIntent broadcastIntent =
                PendingIntent.getBroadcast(this,
                        GlobalConstant.STOP_SHARE_CODE, stopShareIntent, PendingIntent.FLAG_UPDATE_CURRENT);
        builder.addAction(GlobalConstant.NO_ICON, getString(R.string.air_presence_stop_share), broadcastIntent);
        // 创建通知并返回
        return builder.build();
