# Spark如何将数据写入到DLI表中
使用Spark将数据写入到DLI表中，主要设置如下参数：
- fs.obs.access.key
- fs.obs.secret.key
- fs.obs.impl
- fs.obs.endpoint
示例如下：
import logging
from operator import add
from pyspark import SparkContext
logging.basicConfig(format='%(message)s', level=logging.INFO)
#import local file
test_file_name = "D://test-data_1.txt"
out_file_name = "D://test-data_result_1"
sc = SparkContext("local","wordcount app")
sc._jsc.hadoopConfiguration().set("fs.obs.access.key", "myak")
sc._jsc.hadoopConfiguration().set("fs.obs.secret.key", "mysk")
sc._jsc.hadoopConfiguration().set("fs.obs.impl", "org.apache.hadoop.fs.obs.OBSFileSystem")
sc._jsc.hadoopConfiguration().set("fs.obs.endpoint", "myendpoint")
# red: text_file rdd object
text_file = sc.textFile(test_file_name)
# counts
counts = text_file.flatMap(lambda line: line.split(" ")).map(lambda word: (word, 1)).reduceByKey(lambda a, b: a + b)
# write
counts.saveAsTextFile(out_file_name)
